Modding Top 10 PC modders' tools
Discussion in 'Article Discussion' started by brumgrunt, 14 Nov 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. yuusou
    yuusou Multimodder
    5 Nov 2006
    To narrow it down. We like things that cut things.
  3. Griffter
    Griffter What's a Dremel?
    1 Jun 2012
    im not a modder, but those tools make me go ohhhhhhhhhhh, would love to have those in my workshop!... once i get a workshop after getting my house.
  4. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    That is exactly how I feel... lol
  5. Guinevere
    Guinevere Mega Mom
    8 May 2010
    I know it's not great for modding, but it's brilliant for UN-modding... or 'un' anything really! It's my favourite tool in the toolbox and it's very satisfying to use:
    Ladies and Gentlemen, may I introduce the fubar:
  6. blacko
    blacko What's a Dremel?
    30 Jul 2012
    you missed a hammer off the list. You've got to have a big hammer. If something goes wrong the hammer can fix things by smashing stuff into a million pieces.
  7. daletur328
    daletur328 What's a Dremel?
    5 Jan 2010
    For me, has to be good variable solder station and good set of wire strippers. But never seen the dremel scroll saw before.
  8. Jay88018
    Jay88018 What's a Dremel?
    5 Sep 2012
  9. David
    7 Apr 2009
    Can someone buy me the scroll saw and band saw, so I can have the full set?
    and a CNC milling machine
    and a 3d printer, that's it.
    and a laser cutter, that's definitely it, this time.
  10. TadZilla
    TadZilla tadbitnerdy
    5 Nov 2009
    Don't forget a step drill bit to go with that drill. Cleaner cuts than a hole saw.
  11. Stef
    Stef What's a Dremel?
    14 May 2008
    Accurate measurements!
    - Good quality metal ruler (with metric and imperial).
    - Good quality T square thingy.
    Paper and pen/pencil, depending on how detailed you want to sketch, up to A3 in size.
  12. Baz
    Baz I work for Corsair
    13 Jan 2005
    Just dropped £lots on a full set of engraving gear, mod mode engaged!
  13. The Bodger
    The Bodger What's a Dremel?
    26 Dec 2003
    One tool I love is my Antex GasCat. It's a combination of soldering iron, mini - blow torch, mini - heat gun (good for heat - shrink etc) and hot - knife attachment for shaping plastic. It may be something of a jack-of-all-trades, but its portability, cordless operation (it runs on cigarette lighter fuel) and small size make it an extremely flexible device indeed. It's just as useful mending wiring on a car miles from home as it is modding power supply wiring in a PC :)
  14. Cheapskate
    13 May 2007
    I think the one item REALLY missing in you list was a hack saw, -or maybe one of those little engineering rulers.
    @Guinevere - Not a big fan of those. Things that try to do everything normally
    fail. I usually dual-wield two mini crowbars for light-duty destruction.
  15. fluxtatic
    fluxtatic What's a Dremel?
    25 Aug 2010
    I'd second Stef, more or less. I love the triangular Alumicolor scales (although I waste god knows how much time turning and flipping them, seeing as how I only really use the standard ruler side.) Also been meaning to see if they have metric versions, as imperial's getting a little less satisfying every time I measure something. I use 6" and 12" both - the 12" is a little unwieldy for measurements on small pieces, while obviously the 6" is less than ideal for longer lines.
    Other than that, I get by with a Dremel, cordless drill, a few files, and a load of sandpaper (and a sanding block - essential for getting flat, clean edges on plexi, imo.) Next on my list is a drill press, though. Nothing extravagant, just a benchtop job - trying to drill holes square to a face is an exercise in frustration, either with a drill or a Dremel. A bench vise would be good, too - I realize some of the issues I have isn't just a lack of skill - it's hard to do precision work when you're limited to two hands - one holding the tool, the other holding (or holding down) the workpiece.
  16. stanonwheels
    stanonwheels What's a Dremel?
    8 Nov 2011
    Plasters.
  17. hrp8600
    hrp8600 What's a Dremel?
    12 Mar 2009
    A Plasma Cutter for when a Dremel needs to go up to 11
Tags: Add Tags
