Graphics Top 5 ATI Cards Under £150?
Discussion in 'Hardware' started by TheRealShep, 27 Mar 2011.
  1. TheRealShep
    TheRealShep ssSSSsssssssSSSSSSSSSsss
    14 Mar 2011
    As the title says...
    Im looking to build a compact rig but after talking to a lot of people I still can't decide what GPU to get, Ive been told by people on here the GTX460 1GB is really god but then a few of my other mates have said that ATI do a few good cards in my budget and that nVidia had an issue with updating their 1gb cards or something?
    Anyway jsut wondering what the top 5 recommended ATI cards could be so I thought I would post on here and see what you guys said.
  2. murraynt
    murraynt Modder
    6 Jun 2009
    Second hand 5870.
    Second hand 5850
    6870
    6850
    That's the best of them really.
  3. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    +1 for a 5870, can be had for around £140-150 and it would stomp all over a gtx 460
  4. TheRealShep
    14 Mar 2011
    Currently looking at all 4 options :)
  5. murraynt
    murraynt Modder
    6 Jun 2009
    Just keep in mind that the 460 is a powerfull card and on par with the likes of the 6850 and nearer the 5850 than you would think.
  6. KidMod-Southpaw
    28 Sep 2010
  7. Instagib
    Instagib Minimodder
    12 Mar 2010
    If you can get your hands on a second hand 5870, you'll be on to a winner there.
  8. TheRealShep
    14 Mar 2011
    So is nVidia better or is ATI better? Bearing in mind it has to last, Im not going to be upgrading it every 6 months so its gotta last for about 2-3 years hopefully...
  9. mucgoo
    mucgoo Minimodder
    9 Dec 2010
    I wouldn't go fora 5850/70. DX 11 support is sketchy.
    At £150 it's a choice between a 6850 and 460 1gb
    there basically equal on price and performance
  10. TheRealShep
    14 Mar 2011
    Ok so without going for the cheapest one, which manufacturer should I go with for each? Someone on here suggested the MSI GTX460 OCedition at £120 but there were others at a bit of a higher price... would I be paying for brand more than performance?
  11. Strudul
    Strudul ~
    31 May 2010
    There is no better.
    Its just a matter of nvidias 3d vision and cuda and physx VS ATIs eyefinity and bad drivers :p
  12. Strudul
    Strudul ~
    31 May 2010
    Your paying for warranty, aftermarket coolers, factory overclocking...
    Id recommend the msi cyclone or twin frozr OR the gigabyte one.
  13. adidan
    25 Mar 2009
    If you could stretch to £180 the 1GB MSI GTX 560 Ti Twin Frozr is on Today Only at Scan for just under that.
    That's the best bang/buck card at the mo, that and the AMD 1Gb 6950 although they tend to be a tad more expensive.
    Edit: Hang on. Sapphire 6870 for £151+postage if you don't mind buying from Pixmania clicky
  14. Strudul
    Strudul ~
    31 May 2010
    I would not recommend Pixmania :/
    Its french
  15. TheRealShep
    14 Mar 2011
    I wish I could afford £180 but honestly the budget Ive got is already stretched so its a case of see what I can get with what I have...
  16. dancingbear84
    dancingbear84 error 404
    16 Oct 2010
    Not sure on price but evga have a10 year warranty and a trade up program IF you register within so many days. It would be my choice I'd you want longevity
  17. javaman
    javaman May irritate Eyes
    10 May 2009
    xfx is usually 2 years, gigabyte and asus are usually 3. overclockers.co.uk have offers on from time to time tho I've had problems ordering from them before. Ebuyer and scan are better bets.
  18. docodine
    docodine killed a guy once
    10 Feb 2007
    If this is the card going into your tiny lanbox, make sure you take power consumption into consideration. The 5870 is a wonderful value right now (ignoring driver issues) but it's quite large and power hungry.
  19. Marine-RX179
    Marine-RX179 What's a Dremel?
    24 May 2010
  20. TheRealShep
    14 Mar 2011
    Cool, nice spot! I'll give it a look and see what I think. I have everything else ordered/ready to order now so its just the GFX.
    Dan
