Motors Torx screws/bolts
Discussion in 'General' started by peteone, 20 Jan 2007.
  1. peteone
    peteone Minimodder
    5 Jun 2002
    No realy motors specific but its for my car so anyone know where I can get some torx screws in the UK? Around a size 25? Im after the security ones with the hole in the middle.
    Cheers.
    Pete.
  2. Deathrow
    Deathrow Minimodder
    30 Jul 2005
    Your best bets eBay, I picked up a pretty neat set for about £15.
  3. ufk
    ufk Licenced Fool
    3 Jan 2004
  4. Pookeyhead
    30 Jan 2004
    Halford do a Torx set, both 3/8th and 1/2 inch drive.
  5. Deathrow
    Deathrow Minimodder
    30 Jul 2005
    Thats what I bought originally until I found out I could get alot more of the same quality for cheaper off eBay.
  6. Prometheus
    Prometheus Minimodder
    26 Jun 2004
    Maplin do a security bit set that has the torx bits with the holes in, not sure if the T25 bit is in there but I think it is.
    The item code is: N26AN and it's £9.99
  7. peteone
    peteone Minimodder
    5 Jun 2002
    Cheers for the replys chaps. Its actualy the bolts Im after not the Torx driver set:) tanks for the link unluckyfriedkitten thats exactly what Im after, only they seem to sell them in packets of 100 :( Im only after 2 lol
    thanks anyways :thumb:
  8. Prometheus
    26 Jun 2004
    In that case a scrap yard is your friend:) endless supply of torx screws.
