Peripherals Toslink or analogue?
Discussion in 'Hardware' started by Kronos, 5 Nov 2014.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    Looking to get myself a new set of speakers, either 2.0 or 2.1 and wondered as I have a toslink connection on my mobo whether this would be a better way to connect speakers. Also looking for suggestions in the £50 range.
  2. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    depends what you are plugging into I guess. the toslink is a digital connection, so depends if the DAC on the other end is any good. It could potentially be worse than just plugging in analogue.
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
    Cheers mate that confirms what I was thinking.
  4. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    You'll probably find that not many or even no 2.0 or 2.1 speakers under £50 will have an Optical connection on them anyway as I found out when I was looking for speakers for Dizzy in his thread.
    I also seem to remember reading somewhere that if you have a discreet audio card, a digital connection coming from it would just pass straight through rather than going through all the fancier, upgraded chips and whatnot on the discreet card. This could be nonsense however :hehe:
  5. Kronos
    Kronos Multimodder
    6 Nov 2009
    I quite like the 910's you mention in the linked thread.
    Can you explain further what you mean in the last bit of your above post? I don't have a sound card in my Parvum field. The reason I would prefer toslink as I have it on my tv with the sound bar and the sound is clearly superior than the other options to connect.
  6. DIZZY DAZZLER 2010
    DIZZY DAZZLER 2010 Tech nut!
    23 Feb 2010
    To be fair I swear by to tos link and have recently been in the same boat as you as I also wanted a set of speakers with optical in. In the end I purchased a second hand denon m39 amp that has optical in and coupled with my monitor audio bx1's that I nicked out my living room, I am now hearings games like never before.
  7. lancer778544
    5 Jan 2011
    If you don't have a discreet sound card Glenn then I'd ignore that last bit. I was basically saying that digital is digital so if you had a sound card, it would be wasted if you got a set of speakers with Optical/Coax as all the processing would be done by the speakers, rather than the card.
  8. Kronos
    Kronos Multimodder
    6 Nov 2009
    Got you mate, cheers. Think I will treat myself and get the Solo 8C's.
