Other Total Media Theatre 6
Discussion in 'Software' started by halfinched, 1 Jun 2013.
  1. halfinched
    halfinched What's a Dremel?
    19 Jul 2010
    Hi,
    I have total media theatre 6 and have just started watching Spartacus Gods Of The Arena box set on bluray through it. Disc 1 played perfectly. Disc 2 unfortunately only seems to want to play back in 3d which given that i have a 2d tv means everyone is a wonderful shade of green and purple.
    Nothing I do seems to get it to playback in 2d - any ideas? The disc will playback in 2d through XBMC and I believe there is a 3d battle scene on the box-set somewhere which i'm guessing is this disc but I have no idea why its forcing the entire disc to play in 3d and not just the battle scene in the extras...
  2. saspro
    saspro IT monkey
    23 Apr 2009
    Have you tried selecting 2d in the option menu whilst the disk is playing? You should be able to right click to get it (or press the "i" button on your remote control)
  3. halfinched
    19 Jul 2010
    yeah i did try that. It wouldn't change - hence my frustration. Just had a reply from arcsoft though and apparently i need to set 2d mode before playing movies:
    open 3d drop down list.
    disable "always play blu-ray 3d movie in 3d mode"
    and then it should work - so will have to try it tonight.
  4. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    mostly the 3d track is on a different disk then the 2d track due to space required. Might it be that you have inserted the wrong disk?
