Modding Touch sensitive Power button
Discussion in 'Modding' started by gilljoy, 31 Jan 2011.
  1. gilljoy
    gilljoy Minimodder
    14 Nov 2010
    Just wondering if anyone has any experience with this sort of idea.
    Looking to mod my case, going to post up my plans soon and get some advice. One of my ideas is a touch sensitive power button ala the phat playstation 3.
    my idea is a thin piece of perspex above a switch. Hopefully have the perspex flush with the top of my midgard and just thin enough so that when the computer is on you can see the glow of the Led.
    I've got hardly any experience with electronics at all so thats where I need some advice.
    any help at all will be very interested :D
  2. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
  3. Mattmc91
    Mattmc91 Minimodder
    18 Oct 2009
    Doesn't the Cosmos S have one? work from that :)
  4. talladega
    talladega I'm Squidward
    18 Aug 2007
    I made one. It was really annoying and didn't work properly at times. I'm sure it's possible to make one that does work properly though.
  5. jrs77
    jrs77 Modder
    17 Feb 2006
    What about piezo-switches? Way easier then touch-sensitive and they look and work just the same basically from a design-POV.
    You can buy them for $20 ready to go.
  6. THP Dan
    THP Dan What's a Dremel?
    21 Jul 2009
    Ive built some this week, i used a Picaxe 18m2 and a simple code.
    you can have up to 4 buttons off one chip too ;)
  7. ac22297
    ac22297 What's a Dremel?
    24 Jan 2011
    I've actually had a very close look at the innards of PS3 touch controls, and although I'm not well versed in electronics I can say I don't know how they work :S
    The part you touch has a little "z" shape of metal under it. Touching that bare metal on its own without putting any pressure on it switches on the console - I wondered at first if the tip of the "z" shape bent down when pressed and made a circuit but its a single piece :shrug:
    What jrs77 said about piezos looks good to me. But then to me the word "piezo" is synonymous with "magic".
    Anyway good luck.
  8. MightyMorff
    MightyMorff What's a Dremel?
    26 Nov 2010
    I had the same idea with my case mod, though I plan to use the eject button to eject a dvd from the stealth face plate on my tj-07 .
    I think, though I'm not sure, that the PS3 uses cappacitive touch buttons that detect a voltage drop when the button is touched, which then opperates the required function by some clever electronics or magic stuff that happens inside.
  9. carpetmonster
    carpetmonster What's a Dremel?
    27 Jan 2011
    Funny how these things were all the rage and now you don't see them much. However, there were different 'sensitivities' of these things, with ones that worked if you almost just looked at them and some which needed reasonably firm contact, without any actual movement.
  10. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
  11. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    All my buttons are touch sensitive ..i have a touch like a baby elephant mind ..
  12. HowY
    HowY What's a Dremel?
    14 Feb 2005
  13. InSanCen
    InSanCen Buckling Spring Fetishist
    30 Mar 2005
    Quantum Tunneling Compound possibly?
  14. Boscoe
    Boscoe Electronics extraordinaire.
    5 Jan 2010
    Why is everyone over complicating this? What's wrong with a nice old Darlington pair?
  15. bulldogjeff
    2 Mar 2010
    Why not just steal the button of a dead PS3. Some one out the in bit-tech land is bound to have one sitting around.
  16. ac22297
    24 Jan 2011
    funny you mention it....
    lol no bad ac22297
    shouldnt sell other peoples ps3 components
    go sit in the corner
    *slinks away*
  17. MightyMorff
    26 Nov 2010
    I bought some replacement buttons for the PS3 thinking that they might be more technical than they actually are, they are in fact just painted aluminium blocks.
    they attach to a PCB via a length of metal spring just to transfer the capacitance of a touch, or something.
