Electronics Touch Sensitive Power Switch
Discussion in 'Modding' started by dubsjw, 8 Dec 2011.
  1. dubsjw
    dubsjw What's a Dremel?
    1 Nov 2011
    Is there anywhere that sells touch sensitive power switches for computer or any other places that sell switches that can be converted to touch sensitive ones?
  2. SilveR_172
    SilveR_172 Minimodder
    24 Nov 2011
    coolermaster parts store but the cosmos s power pnl and then mod to fit
  3. bigkingfun
    bigkingfun Tinkering addict
    27 Jul 2008
    What you need is a piezo electric switch.
    A lot of stores sell them. I recommend mouser.com but they can be a tad expensive.
    Try ebay!
  4. THP Dan
    THP Dan What's a Dremel?
    21 Jul 2009
    Try the Picaxe M2 range, got the 18M2 running my power, eject and light buttons atm, works great :)
  5. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    I have seen that autozone now has some touch sensitive switches now as well.
  6. yoishiro
    yoishiro What's a Dremel?
    8 Nov 2010
    what is this Picaxe M2 range you speak of ?
    and , can u put some pics / vids , i've been trying to do a touch panel for power , reset and CD tray open thing
    maybe u can help me out
    btw , anyone seen the Playstation 3 touch sensitive panel ? its like a little metal plate shaped as a < , and with the slightest presure , it activates . i wanna do something like that for the CD tray
  7. ALS
    ALS Minimodder
    13 Jan 2012
