Electronics Touch Sensitive switches?
Discussion in 'Modding' started by CryoTeK, 30 Jul 2002.
  1. CryoTeK
    CryoTeK What's a Dremel?
    13 Feb 2002
    I know theres LDR that can act as a sort of touch sensor but i fiqure if i was in a dark room it wouldn't work at all.
    What i am after is a switch that when touched activates, i could use micro switches and stuff but i want that futuristic feel.
    I've seen some (house) light switches that when you wave you're hand past it the lights turn on.
    Any ideas?
  2. lcdman16
    lcdman16 What's a Dremel?
    19 Jul 2002
    buy a universal TOUCHSCREEN remote for your tv, and mod it up to an infared reciever. :idea: This sounds like a great mod in the making!!
  3. CryoTeK
    13 Feb 2002
    lol nothing that extravagant
  4. NiHiLiST
    NiHiLiST New-born car whore
    18 Aug 2001
    I considered this for a while a little time ago. The best I could come up with is an inset cube type arrangement. LED on the ceiling of it, LDR on the bottom, then stick ur finger in it :)
    Code:
    |      ___________       |
    |      |   \_/   |       |
    |      | _______ |       |
    Like that.
  5. Draxin
    Draxin Seeker of Photons
    29 Nov 2001
    i dont have the addy been im working with those now. they are IC's they work as touch switches, they will even sence through things like Plexi, so you dont even see the IC its hidden behind the plexi. its sweet.
    put it on a metal plate and it becomes a proxy switch you only have to get near it for it to switch over. its sweet stuff. Bug linear he gave me the link to start with.
    Linear is a gold mine of INFO
  6. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    i remember the monitor on my first PC (old 10" cga job) had touch switches on it.. what a pain, if your fingers were too cold, or oily the thing wouldnt come on.. lol no clue how those things work tho.. linear??
    -scoob8000
  7. mookie
    mookie very nawty<br><img src="http://mookie.org/i/avatar
    30 Jun 2002
    i know i'm not linear but....
    my mom has a monitor with touch buttons and while trying to figure out how thy work i tied a few things:
    1. finger - yes
    2. pencil - no
    3. hot breath - no
    4. metal paperclip - yes
    so her's had to conduct electricity to "flip" the switch. i beleve mosfets(sp?) are sensitive enough to make push button switches. but i don't know how.
  8. CryoTeK
    13 Feb 2002
    Linear, Linear, where for art though Linear.
    Yea the other way i thought of doing it was like NiHiLiST said with an LED or sumother lighting sorce on the LDR.
    But we shall see where this IC line goes
  9. Hylsan
    Hylsan What's a Dremel?
    23 May 2002
    this is what you are looking for;
    pased from Linears IC-workshop thread (a thread you all should have read :) )
    QT11x
    Touch sensor ICs
    Street price $3 or less
    This is a family of ICs that implement the capacitive touch switch function in a convenient package. It autocalibrates, making it a real non-headache to use. It will detect a touch (change in capacitance) even through gloves or a nonconductive panel (acrylic for example). QT113 is designed for extra sensitivity for use behind thick panels and has a continuously adjustable gain.
    Applications:
    Touch switch control for anything that uses a conventional switch. BorgBob's LCARS panel.
    Degree of Difficulty: low
    There's a minimal external component count with this product. You ay need to interface the logic output of this to a relay in order to close physical contacts (to emulate a reset button or power button) but in other cases, the logic output is usable directly.
    http://www.qprox.com/products/qtouch.php
    very cool stuff..gonna buy me a couple of those later this year to see how they work....dont have the money right now becouse im out of job :(
    mind if i ask what you are planning to builld? :)
    /Hylsan
  10. CryoTeK
    13 Feb 2002
    Woohoo.. i think we have a winner.
    This sound's exactly like what i want.. and if it can work throught thisk matireals thats even better.
    Thanks alot guys
  11. CryoTeK
    13 Feb 2002
    Wouldn't have any idea if theres a NZ supplier would ya?
    Not to worry i found one MUHAHA
  12. Draxin
    29 Nov 2001
    So what is it your planing on building??
  13. CryoTeK
    13 Feb 2002
    Well among other things .. H-bomb and suchlike
    i thought that i would use it for my CD-Rom and other asuch like applications.. This being that i can stealth my CD drive and not have to worry aobut the powe button as i would just have to make a wave of my hand and it will open.
    But as soon as i get my FREE sample (they are letting me havea free sample i love it) i will tell you if it was succesful or not
  14. linear
    linear Minimodder
    5 Oct 2001
    Shall I hear more, or shall I speak at this?
    Erm, yeah, looks like this sorted itself out without my help. CryoTek, lemme know if this works out for ya, I'm interested in this IC but it's waaaay down my to-do list unfortunately.
    I did read the datasheets and it looks like an easy implementation.
    They're sticky for a reason....
  15. Shadowspawn
    Shadowspawn Another hated American.
    1 Jul 2002
    Must....have....wiring diagram...for those of us that aren't smart enough to figure it out for ourselves, but have no problem following pictures!
  16. linear
    linear Minimodder
    5 Oct 2001
    How's this:
  17. Shadowspawn
    1 Jul 2002
    Damn.
    Ask, and you shall receive!
    Thanks.
  18. TrumpetSteve
    TrumpetSteve What's a Dremel?
    21 Feb 2002
    Two Questions:
    1. Can this run on 12V?
    and
    2. When you order from the site listed above (http://www.qprox.com/products/qtouch.php)
    does this include everything you need to get started (proxplate, etc.) or just the IC?
    Thanks
  19. JazzXP
    JazzXP Eh! Steve
    30 Apr 2002
    Looking at the diagram... it looks like a max of 5 volts
  20. GreySpaceAlien
    GreySpaceAlien What's a Dremel?
    27 Jul 2002
    You will get only the IC, but the prox plate can be just about any hunk of conducting material.
