Case Mod - Complete TOXIC CHROME (modded Corsair 250D)
Discussion in 'Project Logs' started by ciobanulx, 8 Apr 2015.
  1. Bygone
    Bygone Minimodder
    15 Apr 2015
    Thx for the answer :) looks clean enough. I should have done the same on my build but it being my first didnt think of it :), keep up the good Work.
  2. ciobanulx
    ciobanulx Modder / Watercooler
    24 Jul 2014
    No worries man :D Thanks!
  3. ciobanulx
    24 Jul 2014
    Hey guys,
    Front panel is done and here is how I applied it on, very simple with some double sided 3M tape.
    For some reason these following pics I only have from my phone, not sure what happened with the ones from the camera :(
    Thanks for checking it out and hope you guys like the finished front panel!
    Cheers,
    Alex
  4. tkh
    tkh Minimodder
    1 Mar 2006
    Love it mate!
  5. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    really goodlooking and compact case! =)
  6. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Looking sweet man! :thumb:
  7. ciobanulx
    24 Jul 2014
    Thanks a lot guys :D
  8. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Clean work Alex! :clap:
  9. ciobanulx
    24 Jul 2014
    Thanks a lot Bill! :D
  10. ciobanulx
    24 Jul 2014
    Hey guys,
    Another quick update. The GPU is good to go and I also cut up these fan frames that will go around all the fans in the build to give them more colour.
    You can see on the GPU the pink and purple caps have been covered with chrome vinyl.
    This is the design I went for with the frames to just cover the edges of the fans.
    Just need to get painted and filed down a little bit more, will be same silver colour as the side and front panel.
    Thanks for checking it out.
    Cheers,
    Alex
  11. mnpctech
    21 Apr 2003
    looking good :clap:
  12. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    Very clean looking mod, love it
  13. ciobanulx
    24 Jul 2014
  14. mnpctech
    21 Apr 2003
    Can't wait to see it completed! :hip:
  15. bionicgeekgrrl
    bionicgeekgrrl Minimodder
    1 Oct 2009
    lovely work :)
  16. ciobanulx
    24 Jul 2014
    Thanks a lot! Sorry for the lack of updates, been so busy moving house over the last few weeks. Nearly done and should have an update pretty soon and wrapping this build up soon too :)
    Cheers,
    Alex
  17. ciobanulx
    24 Jul 2014
    Hey guys,
    Sorry for the lack of updates on the build. I have been very busy moving houses over the last few weeks.
    All done now but no internet at home yet, so posting update from work. Should have a lot more room and time to work on builds from now on and will hopefully wrap this build log up soon but I'm still waiting on custom cables to arrive.
    Here are the finished grills/covers I made for the fans.
    Stay tuned for more.
    Cheers,
    Alex
  18. ciobanulx
    24 Jul 2014
    Hey guys,
    More work in progress! Found a nice spot for The Mod Zoo monkey badge and it looks pretty nice in there.
    Just a few things to fix up and start working on some cable management for the fans and LEDs. Once the sleeved cables arrive and I can get everything in and start tubing up finally!
    The two mounting holes for the 80mm fan grill don't really match unfortunately so will need to fix that :)
    And here's a better look at the finished front panel.
    Stay tuned for more!
    Cheers,
    Alex
  19. Vognen
    Vognen Minimodder
    2 Oct 2013
    Was just about to ask for updates, and BAM! You just dish out an epic one :naughty: I really like what you're doing, and it'll probably look epic when you're done :D
  20. ciobanulx
    24 Jul 2014
    Thanks a lot, not too far now :D
