Tracking IPs via instant messengers
Discussion in 'General' started by Ubermich, 27 Sep 2004.
  1. Ubermich
    Ubermich He did it!
    21 Jun 2002
    I know with AIM you can direct-connect and look for a connection on port 443 or 4443 via netstat-n is there a way to do something similar with MSN and yahoo?
    Just curious. I got one of those lovely nigerian scams and want to track him down. I have two yahoo.co.uk email addresses so far...
  2. B-Con
    B-Con What's a Dremel?
    4 Jul 2004
    The only way, to my knowledge, is to send the user a file, once/if they accept, then use netstat -n and you'll see a "temp" connection listed....
  3. RTT
    RTT #parp
    12 Mar 2001
    Do yahoo allow you to see the full mail headers? If so, you should be able to get his IP from there in the 'received-from' field.
  4. Dinh
    Dinh What's a Dremel?
    27 Jun 2004
    Yeah there are programs to do this, but you will have to google them.
  5. FuzzyOne
    FuzzyOne
    19 Sep 2002
    You can do 'netstat -a' whilst in a conversation
    EDIT: I think yopu may need to be sending them a request of some sort like a file or to play a game view there webcam etc etc
  6. ou7blaze
    ou7blaze sensational.
    5 May 2003
    I thought MSN decided to ban or block this type of activity for example they blocked some ports or something to fix the hack / program called "msn block detect.exe" everyone was using to check if they were blocked by a user and who had deleted them, and who added them etc as it was against the rules or bad for someones privacy or whatever.
    That's just what I think...dunno google the programs out...
