Tranc3's free computer adventure
Discussion in 'Hardware' started by tranc3, 10 Mar 2008.
  1. dazmanultra
    dazmanultra What's a Dremel?
    17 Jan 2004
    That Celeron really doesn't need that many case fans. :p
    However, it can probably be overclocked quite readily to 3.2Ghz. Change the FSB on your motherboard to 133, make sure the PCI frequency is locked to 33mhz or the divider is set to 4, increase the vcore a touch (5%) and you'll get a nice speed boost from 2.4Ghz to 3.2Ghz. :)
  2. Squadexodus
    Squadexodus I got my cookie. What about you?
    5 Jan 2008
    MOAR FANS!
    You should see how many fans you can fit in the case... :D
  3. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    Well, took a shot at cable management, replaced the celeron with a P4 that i had sitting around in a dell. and still the total cost is a whopping $0
    I some how managed to make ide ribbons look good.
  4. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    Heres the latest shot. did a quick window in it with 500mph. going to put some more paint on it. might try to sleeve the cables with something black if i can find any thing.
