Apple Transfer Filesfrom Mac to PC
Discussion in 'Software' started by xilron, 7 Jul 2005.
  1. xilron
    xilron What's a Dremel?
    22 Jan 2003
    Hey-
    I have a mac and I need to get files from it to a Windows XP PC wihtout installing software. I can get both boxes into the same room. I was thinking about a crossover cat5 wire, but I wasn't sure if it would work between a PC and a mac.
    Let me know if you guys have any other ideas by posting back.
    Thanks, Xilron
  2. macdude425
    macdude425 What's a Dremel?
    13 Mar 2005
    What operating system is the Mac running?
  3. bennifer
    bennifer What's a Dremel?
    26 May 2004
    Yeah, a crossover would work fine.
    Goto system preferences -> sharing and enable windows file sharing. It should all mesh up automatically :)
  4. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    If it is a newish mac then any network cable will do the job. enable windows file sharing or ftp and you can access it from the windows pc.
  5. pritsey
    pritsey Minimodder
    26 Nov 2002
    OS X has a built in FTP server, switch it on and you can just connect to it over a network (or cross over cable) via internet explorer if you need to. Works a treat.
  6. Kevo
    Kevo 426F6C6C6F636B7300
    9 Sep 2001
    Or you could just click on the "connect to server" menu and type in cifs://servername/sharename or smb:// etc...
    No pissing about with the windows file shareing bollocks or ftp ;)
