Modding Transparent Blue CDRW or DVD-ROM
Discussion in 'Modding' started by JavaDog, 9 Apr 2004.
  1. JavaDog
    JavaDog What's a Dremel?
    13 Mar 2004
  2. bee2643
    bee2643 What's a Dremel?
    7 Mar 2002
    uhhhhh lol
    i think its cheesy
    id rather take a stab at making my own :D
  3. atv_freak
    atv_freak What's a Dremel?
    8 Jan 2004
    They look pretty cool, better than just plain black or biege(sp?).
    I have the Artec version of the DVD drive. Put a few more blue LEDs in and it would look awesome! :rock:
  4. JavaDog
    13 Mar 2004
    Yeah, but unless you have a way of molding plastic (I do :p) the best you will get is a very basic stealth-type of cover...
  5. whiteagle
    whiteagle What's a Dremel?
    28 Aug 2003
    Please, do tell more. :confused:
    I've been doing some basic stuff with acrylic (bends, basic molding, and welding) but I'm trying to get better at it and trying to use different types of plastics.
  6. Xgamer
    Xgamer What's a Dremel?
    29 Oct 2003
    It might look good if used with a clear case that has blue lighting already in it.
  7. Twitch
    Twitch What's a Dremel?
    13 Mar 2004
    Or green lighting
  8. JavaDog
    13 Mar 2004
    Yeah, nothing says you couldn't change the LCD's to match your case/scheme... :naughty:
  9. JavaDog
    13 Mar 2004
    I built a small 12" x 12" Vacuum Forming table (Total Cost = $50) for doing basic molding work. Maybe I will put up a How-To in a bit...if anyone would be interested.
  10. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    plaster could work fine aswell... depends on what to be molded...
    but javadig: i'm interested... sounds cool :) :dremel: :thumb:
  11. bee2643
    7 Mar 2002
    you could make a vacuum molding if you have ways of making a cast thats susceptable (sp?) to high heat
    or you could melt acrylic with a heatgun and (wearing gloves, of course) mold it to something...this method worked for me...it was kinda sketchy htough
  12. whiteagle
    28 Aug 2003
    Definitly interested! :dremel:
  13. theagent
    theagent What's a Dremel?
    4 Nov 2003
    any luck on that guide, java? i'd sure like to build a good machine :)
