Anyone know where i could get a transparent side panel for a haf 922? I bought one with just the mesh side, it leaks alot of noise plus a transparent side panel would look 10x better
They used to sell it in the coolermaster store but I can't see it listed now. Drop them an email. I've always found them to be very helpful when I've had to contact them. http://www.coolermaster.nl/shop/
Pretty sure the HAF X 922 and 932 are identical when it comes to side panels etc http://www.coolermaster.nl/shop/product_info.php?cPath=88&products_id=709
Don't think so. 922 Dimension (W / H / D) Main: 253 x 502 x 563 mm / 10.0 x 19.7 x 22.2 inches 932 Dimension (W / H / D) (W) 243 x (H) 560 x (D) 564 mm The side panels are different design and from the differing size of the cases I would also say different size.
Well I looked at the nVidia versions of front/sides etc and they appeared to fit. I may be wrong but hey only an idea lol
