Case Mod - In Progress TrashCan wayward
Discussion in 'Project Logs' started by NameAlwaysInUse, 23 Mar 2016.
  1. NameAlwaysInUse
    NameAlwaysInUse What's a Dremel?
    11 Dec 2014
    TrashCan wayward
    (I should only be a trash can)
    Prolog:
    On a cold rainy Sunday afternoon Mr. NameAlwaysInUse decided, in the Bavarian capital, it was the perfect day for getting a new bathroom waste bin - ONLINE!
    So he scoured the vast worlds of the Amazon’s, fought with leopards, tigers and alligators, as his eyes suddenly grazed the Authentics Lunar. It was small, well-formed and had a shiny white paint. So he had found him, the holy grail of waste bins.
    But how could he bring it home in one piece? After all, he was surrounded by many wild animals! NameAlwaysInUse opted then for a courier of the Amazon’s Logistics fleet. Will said Grail arrive home on time, and more importantly, unharmed?
    Finally, three days later, Mr. NameAlwaysInUse’s door rang, he ran to the intercom, was it Amazon’s Logistics? The speaker crackled: "I have an express delivery for you ''!
    NameAlwaysInUse opened the door and took the package, but it was heavier than expected. Wrong package?, he wondered. Distressed he opened the package and took the contents carefully from its packaging.
    To his surprise, there was no mistake, but why was it so heavy? After a short investigation, he found that it had to be due to the thick-walled ABS!
    But when NameAlwaysInUse took a closer look at the holy bin , suddenly he realized that maybe he could come up with a better use for it other than storing trash.
    This is how the story of the small trash can begun.
    Case:
    Base: Authentics Lunar 6L
    Bottom: 3D SLS Nylon print
    MB Tray: 3mm Aluminium laser cutted
    Middleplate: 3mm Aluminium laser cutted
    Cap: 3mm Aluminium laser cutted
    Framework: Maker Beam Kit 200mm
    Riser: 380mm A-Type by Li-Heat
    Hardware:
    CPU: Intel i7-6700k
    MB: MSI Z170I Gaming Pro
    RAM: 16GB Crucial Ballistix Elite DDR4
    GPU: Sapphire R9 Nano
    NT: SilverStone SFX Series ST45SF-G
    Cables: Silverstone Short Cable Set SST-PP05
    SSD: SanDisk X400 512GB
    Cooling:
    CPU: Bitspower Summit EF Brass Nickel
    GPU: EKWB R9 Nano incl. Backplate
    Pump: Bitspower DDC Plus and Bitspower Magic Cube
    AGB: Swifttech MCRES Micro V2
    Radiator: Bitspower Leviathan Xtreme 480
    Fans: 8x Noiseblocker eLoop 120mm, 1x Noiseblocker eLoop 140mm
    Fittings: Bitspower Matte Black
    Tube: Bitspower Crystal Link 12mm Ice Red
    Liquid: AquaComputer DP Ultra
    Thermal Compound: Cooler Master MasterGel Maker Nano
    MonitoringAquaero 6LT incl. Kühler ;)
    Lighting:AquaComputer Farbwerk
    Tools
    Multifunctiontools: Dremel 8200 incl. Parallel- and Circlecutter
    Deburring: SANPRO tube deburring
  2. NameAlwaysInUse
    11 Dec 2014
    Here is the small trash can :)
    Let's go
    First we need a small hole for the Dremel Tool
    Destroying the Can!
    Around the world :p
    Now we need our best friend... Sandpaper! And my small dragon :)
    Gesendet von iPhone mit Tapatalk
  3. Supercluster
    Supercluster I dream in G-code
    16 Feb 2015
    Looking forward to seeing the trash-can case! (one proud to be a trash can and not pretending to be something else *cough*youknowwhoyouare*cough*)
    Subscribed!
  4. NameAlwaysInUse
    11 Dec 2014
    Hehe thx :) framework is ready pictures tomorrow.
  5. Vault-Tec
    30 Aug 2015
    If I see one of these done properly I will doff my cap to you.
    Nice to see it's getting some proper hardware too.
    BTW your bottom isn't working (the pic).
  6. disturbed13
    disturbed13 What's a Dremel?
    28 Nov 2008
    is that ment for monkey face?
    * no offence intended *
  7. Hzza
    Hzza Minimodder
    15 Apr 2013
    Awesome concept, subbed.
  8. disturbed13
    28 Nov 2008
    if you like this concept then check out the IronTurnip by Cheapskate, its along the same lines. just using junk, pretty cool.
  9. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    Iron Turnip is quite different and more complex. :rock:
    I think "NameAlwaysInUse" is going to create something like the new Mac Pro and probably he takes inspiration by the Lunar project by Bouly based on the same trashcan. ;)
  10. NameAlwaysInUse
    11 Dec 2014
    First the Iron Turnip is much bigger
    Second Bouly copied the Lunar Project ;)
    Third aircooling is quiet easy in this... Problem is the watercooling :D and this is why i created the log
    @Vault i know. Not uploaded yet
    4x MakerBeam 20 cm
    4x 25mm MakerBeam screws
    12x nuts
    12x 6mm MakerBeam screws
    1x MB Tray
    1x PSU cover
    First screw the Cover directly on the PSU
    Then the MakerBeams for the Tray with 2x 6mm screws.
    Now the Mb spacer incl. 4x 6mm screws
    If the dxf is cutted properly the mainboard fits. ;)
    Short cable.
    Screw mainboard on the two MakerBeam
    Bottom fitting. :)
    Now you recognize that the cap isn't closing, because the MB ATX cable is to thick ;)
  11. Kviker
    Kviker What's a Dremel?
    22 Jan 2010
    that looks like bigmac-pro :lol:
  12. disturbed13
    28 Nov 2008
    i really hope you are going to liquid cool that can
    that would be awesome!
  13. NameAlwaysInUse
    11 Dec 2014
    I will ;) Bitspower already shipped my Order :)
  14. Supercluster
    16 Feb 2015
    Unless I missed something this will be water-cooled externally? (or you could've invented particle shrinker and will reduce the size of Leviathan 480mm :D)
  15. NameAlwaysInUse
    11 Dec 2014
    I tried it but it was to tiny and broke... So external :D
  16. Cheapskate
    13 May 2007
    I heard my name thrown about...
    Internal! WC internally! Even if you have to get a 2nd trash can and the assembly looks like a chubby. :lol:
  17. NameAlwaysInUse
    11 Dec 2014
    The can will be on my tv Wall and the rad IN the wall :D why a second can ;)
  18. disturbed13
    28 Nov 2008
    more room for liquid cooling equipment
    it could be longer and be all internal
  19. NameAlwaysInUse
    11 Dec 2014
    Oh nice idea. increase the height from 28cm to 76cm for the 480mm radiator :D
  20. NameAlwaysInUse
    11 Dec 2014
    Yesterday I got my package! :)
