Tribal mod [ WASTED ! ]
Discussion in 'Project Logs' started by Silenced`, 29 Dec 2004.
  1. Silenced`
    Silenced` What's a Dremel?
    28 Aug 2004
    Thx for the proposal :thumb:
  2. Franklin
    Franklin What's a Dremel?
    24 Oct 2004
    It's looking better and better Silenced! :thumb:
  3. Thrillseekah
    Thrillseekah What's a Dremel?
    21 Oct 2004
    This is getting cool keep up the good work.
  4. Silenced`
    28 Aug 2004
    thx peeps :)
  5. KAMIKAZE-FREAK
    KAMIKAZE-FREAK What's a Dremel?
    30 May 2004
    why dont you have your motherboard atx lead sleeved?
  6. Silenced`
    28 Aug 2004
    because i am scared like hell to f*ck it up and blow up my motherboard ( switch wires or break pins that hold it in the plastic ) so i am watching around for something like spiral thing.
  7. KAMIKAZE-FREAK
    30 May 2004
    you could do like a friend of mine
    cut all the cables of the atx lead just out of the psu
    put the sleeving on but push a bit more then normal to the rest of the cables that you cut off
    and then solder the wires back together
    and push it back again
    the mesh will cover the soldering up
    (dont forget a very important thing with soldering, USE HEAT SHRINK around the soldering so it doesnt make contact with a other object!! )
  8. Silenced`
    28 Aug 2004
    its a good idee, but if you start soldering you can beter soldering it from the print plate of the psu. anyway i work something out, thx for the proposal :)
    grtz,
    Thomaz
  9. greywolf
    greywolf What's a Dremel?
    15 Oct 2004
    I've done this. It's actually rather easy, if you are ok with soldering. Took about 1 1/2 hours to do the Mobo connection, just have to be careful.
    I have step by step pics if you like?
  10. DoNuT
    DoNuT What's a Dremel?
    20 Dec 2004
    Great paint jobs. I've had that damn fly around my paint jobs too...and mosquitoes and those china ladybugs. :wallbash:
  11. Silenced`
    28 Aug 2004
    no thx,
    i don't want to do this.
  12. Silenced`
    28 Aug 2004
    hehe :d
  13. Silenced`
    28 Aug 2004
    hellow!
    today when i had a little free speace at school i made this ( its for the dubbel fans holes at the back of the case ):
    tell me what you think about it ? I wish it was weekend :dremel: modding time :dremel:
    greetz,
    Thomaz
  14. Silenced`
    28 Aug 2004
  15. phoeneous
    phoeneous What's a Dremel?
    16 Aug 2004
    I like it lot. The edges make it look more tribal profile. Honestly, I think it looks much better than the first one on pg2.
  16. Silenced`
    28 Aug 2004
    thx man :naughty:
  17. Silenced`
    28 Aug 2004
    Finally weekend = UPDATE TIME!!! :D
    I started today with sanding my left panel ( with 3 different typed of paper ):
    Than I have sanded my bothem panel ( the inside ), but after painting I got over whole the panel small bubbles diameter 0.5mm :confused:
    But I resanded it and paint it again and it’s normal now :)
    First layer of primer for the left panel:
    And his first layer of paint ( sorry for the bad pic its looks black on this one oO )
    Also i finisht the hd rack ( sanding + painting + varnish )
    And also I have finally my fans and cables ( anyone some tips for getting it on picture, because it never looks like in real life :wallbash: The sleeving of the fans will be for later ( need a fan controller for the 3pins fans )
    Not so much for today but hey if you are awake at 13:30 :wallbash:
    Hope you liked it :d
    grtz,
    Thomaz
  18. Xhiz
    Xhiz What's a Dremel?
    28 Oct 2004
    You have the same monitor I used to have :D mine was 17" with side speakers tho :p
    Anyway, great mod!! and great ideas
  19. Silenced`
    28 Aug 2004
    thx :)
    grtz,
    Thomaz
  20. zerocom
    zerocom What's a Dremel?
    13 Jan 2005
    looks very good, just loving the peintjob, one of my favourite colours...
    tribal theme looks good too.
    best of luck :thumb:
