TRIBALOVERKILL's Project: "Blackout"
Discussion in 'Project Logs' started by tribaloverkill, 16 Aug 2005.
Thread Status:
Not open for further replies.
  1. quadmodz
    quadmodz What's a Dremel?
    9 Oct 2004
    god d*mn nice work! :jawdrop: also I love chrome!!! :D
  2. ou7blaze
    ou7blaze sensational.
    5 May 2003
    Nice humour in the SB meets Moddin' episode lmao...
  3. dex2407
    dex2407 What's a Dremel?
    9 May 2005
    instead of screwing the accents under the shield y dont you glue them and cut a bit out around the screw mount so you only screw down the shield then they should fit flush. if you get me.
    oh and this just gets better and better, but we need more sb. :D
  4. PA!N
    PA!N What's a Dremel?
    16 Jul 2005
    One word:
    !!!AMAZING!!!
  5. simosaurus
    simosaurus What's a Dremel?
    12 Jun 2005
    This is just amazing, perfect work throughout :) i seen your pumps then went back to read the entire thread :D im glad i did tho, cuz its amazing to see what you did to the front of that case (i have one the same). Also that side orbital will look awesome through the dark plexi, makes me wanna put an orbital there too :)
    keep going!
  6. sweeeeeeeeeeeeeeeeetness!! It just gets better! :thumb:
    Oh and a suggestion, how about SB slips with a dremel and decapitates himself? I hate him soooooo much! :dremel: :p :miffed: :grr: :clap: :hehe: :D :worried: :idea:
  7. Nexxo
    23 Oct 2001
    Serious awesomeness happening right here in this thread! :rock: Lordy, lordy, lordy, what crazy messed-up world are we bringing our kids into...
  8. tribaloverkill
    tribaloverkill Who needs sleep,... bah.
    1 Jan 2005
    I really dont want ot glue anything. I am trying to stay away from glue. I'll figure something out. Thanks.
  9. tribaloverkill
    1 Jan 2005
    LOL! You know what,... just for you,... for the project finally,... I will destroy Sponge Bob!
  10. Rh1n0x
    Rh1n0x What's a Dremel?
    15 Nov 2004
    Amen!
  11. 330td
    330td Minimodder
    12 Aug 2004
    omg :waah:
  12. Cheap Mod Wannabe
    Cheap Mod Wannabe What's a Dremel?
    7 Feb 2005
    What will this war machine of your's do?
  13. Jipa
    5 Feb 2004
    Oh my god! You really don't seem to stop amazing me.. Keep it up!
  14. Zebo
    Zebo What's a Dremel?
    7 Sep 2004
    Man I love this project. High levels of detail and explaination is appreciated keep up the good works. :thumb:
    One question. Since you got the bending down pat in those radiator "containers" why did'nt you build your own case too with aluminum sheet?
  15. psyphen
    psyphen What's a Dremel?
    20 Jul 2004
    This should definitely be project of the year :p.
  16. MoOstick
    MoOstick What's a Dremel?
    28 Jul 2005
    OK I must admit you did it... Indeed it looks really sweeat! :rock:
  17. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    way to overshadow my mod..... Great work on those sheild BTW. Can we expect a motherboard cover with the same theme?
  18. tribaloverkill
    1 Jan 2005
    I'm going to play Snood on it :worried:.
    Because I didnt know I could do all this! LOL.
  19. tribaloverkill
    1 Jan 2005
    Gawd,... I was hoping that no one would bring that up. I was going to make one but I decided that I didnt want to be to specific with the modding. This is so that I can upgrade this machine and maintain the look without having to remake certain things. But,... there is one issue that needs attention and thats all the chrome shower hose thats going inside this beast. I dont want to short anything out. My options were too either clear coat all the shower hose(if that would even work) or cut out a black foam cover for the mobo that would pretty much sit flush on the mobo with everything passing through it. Making a new one of those if I ever upgraded would be easy.
    Anyways,... I just got done making the UV green sides for the pumps. I am friggin speechless! Together with the chrome sides,... its sweet lit up! My mouth was hanging open! I have to make the inners now. This will be alot harder to do. I ran the side one through the router which cut perfect replicas of the aluminum sides. The inners,... I dont have anything as a template to run the acrylic through the router. I might have to fiel them by hand. I dont know. You'll find out later how I did it. I'll post pics later a well. Theres going to be alot of pics so warm up them pc's!
  20. tribaloverkill
    1 Jan 2005
    Just went through your log,... you are just starting! You have plenty of time to do something really great with your machine! Don't limit yourself,... if there is something you wan to do,... do it! Good luck bro.
Thread Status:
