Case Mod - In Progress Tribal's case - Christmas update hehehehe 13/12/2007
Discussion in 'Project Logs' started by Rodrigo Vicentini, 30 Apr 2006.
Thread Status:
Not open for further replies.
  1. Darkened
    Darkened What's a Dremel?
    28 Feb 2004
    Hot damn, this is coming along great.
    Seems that you've done some bondo work before in your life too, haven't you :hehe: It's still a bit hard to see the big picture, but I do like what I see from these "evolving" bits and pieces, keep it up.
    Janne
    P.S. I laughed when I saw your keys on the table, nice teeth :D
  2. Rodrigo Vicentini
    Rodrigo Vicentini What's a Dremel?
    30 Apr 2006
    Tks dude :D the teeth are copy of my teeth natural eheheheheh I had never made before anything as this base, for being the first time I think was good.
  3. Rodrigo Vicentini
    30 Apr 2006
    Now I am working the front and the electronic part of the project, this part still doesn't have very material to show, then I decided to do some new buttons for Aerogate III, to test how the final result would be.
    the Aerogate:
    the result:
    4 Fans, Vantec Blue clean UV
    other tests:
    here the Original and on the side it copies her.
  4. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    That base is crazy! I love it.
    Thanks for the props Rodrigo!
  5. DAE_JA_VOO
    DAE_JA_VOO What's a Dremel?
    11 Nov 2005
    How did you make those buttons?
  6. Evenge
    Evenge Minimodder
    16 Sep 2006
    Well your dremel skill realy are something cool... :cooldude:
    Keep up the good work! :thumb:
  7. DuVeL
    DuVeL What's a Dremel?
    4 Apr 2007
    I really love the skull and other tribals.
    Question, do you also do requests? Check your PM-inbox otherwise please.
    Very good!
  8. itsjustacompaq
    itsjustacompaq Minimodder
    7 Sep 2006
    if im not mistaken, he somehow got some extra buttons, or buttons from other aerogates and sanded them down to clear acrylic. then he painted them in a couple different ways.
  9. Rodrigo Vicentini
    30 Apr 2006
    tks dude :D :D
    first I made one copies in silicon of the original button, I used acrylic of dental prosthesis that and more fluid, the only problem that if to do these buttons, it is that if you had needed a pressure cooker type to remove the air bubbles.
    tks dude, I am happy with your comment.
    dude, forgive me for the delay in answering you, I will arrive the box now. thank you for the comment.
    no dude, I did the new buttons in acrylic, later I will put a basic step-to-step here: D
  10. Rodrigo Vicentini
    30 Apr 2006
    now a question for you:
    in the freight I should use:
    Two skull
    or One skulls:
    now one more pictures of illumination:
  11. Rodrigo Vicentini
    30 Apr 2006
    I had to close the old hole of PSU, then I decided to do a new cut (mini-cut to be more exact hehehe), the problem and that I only had a single disk to cut, I thought it would not get, result:
    comments and suggestions for the improvement of the healthy project well coming friends :D
  12. B[x]
    B[x] What's a Dremel?
    3 Jul 2006
    Those are some nice cuts, there. I'll always respect those that can maneuver a rotary tool in small designs. It may not be the best tool for the job but it does the trick in this case.
    I'd go with one skull, two seems like overkill.
  13. Teyber
    Teyber ******
    18 Mar 2007
    wow thats awsome!
    i used to have a mercedes slk, (even though im 15 years old), then my dad got a job.
    hahah jkjk, man i was looking for a place to put that lol im kiddin.
    Excelent dremeling. what dremel is that?(like what model)
  14. Rodrigo Vicentini
    30 Apr 2006
    Tks man, I used a skull only, thank you very much for the comments.
    this is some competitive mark of the dremell, dicamos that and a more popular dremell. the name of the mark and FORT
  15. Rodrigo Vicentini
    30 Apr 2006
    returning my worklog, I will show the front of the project.
    I had made a front different from this, but I committed a mistake when trying to do the mold in plaster, then I decided to change the front drawing, I think this was better.
    here and my work place, very tight
    http://img484.imageshack.us/img484/6817/dscf1661br0.jpg
    refazendo o trabalho todo
    here a picture of as it was the course, a ready side and the other almost finishing, that after some 3 hours
    general vision of the whole thing
    (sentence without any sense heehehe)
    good the part of the wax is finished, now we will make the negative form of this whole wax.
    here and as I decided to do, I divided the front in 4 parts, my previous mistake went to try to do everything at once the front didn't simply leave the plaster, I had to break everything. of this it sorts things out that I did leaves perfectly.
  16. Rodrigo Vicentini
    30 Apr 2006
    filling with plaster, I used plaster special type IV.
    after some 2 hours drying, mold negative leaves with the whole wax in him
    now that the mold loosened and hour of doing the "cover" she will be with the front format, that guarantees the fitting of the pieces in front of the case
    after the ready "cover" and hour of removing the whole wax.
    molds and their covers:
    the tribal of some of the lateral ones:
    and his "cover":
    now the wax transformation for acrylic
    closing the form, will have to press the cover against the form the more possible fort, then I used the chair to do this force in my place hehehehe
    after ready:
  17. ComputerKing
    8 Sep 2006
    DAm! I don't know how I missed this! WOWOW Dude that inside work is amaizng!!!!! Dude every thing is kickass in your case! WOW, Can't wait any more. UPDATE!
    Good luck.
  18. Rodrigo Vicentini
    30 Apr 2006
    Hi Dude, thank you for the comment, excuse the delay but and that I was not with time remaining to continue the project, but now I have innovations
  19. Rodrigo Vicentini
    30 Apr 2006
    hello friends, I delayed a time, but I am back, and with innovations, the project this steering for the end.
    here the mold in plaster of the skull, I don't have picture later without wax because it finished the battery of the camera
    acrylic to do the tribal of the foot of the cabinet: D and the finish to be very aligned with the drawing of the foot.
    here the form of the front door of the case:
  20. Rodrigo Vicentini
    30 Apr 2006
    the skull already ready:
    here pictures of the front and front door mounted:
Thread Status:
