Case Mod - In Progress Tribal's case - Christmas update hehehehe 13/12/2007
Discussion in 'Project Logs' started by Rodrigo Vicentini, 30 Apr 2006.
Thread Status:
Not open for further replies.
  1. Rodrigo Vicentini
    Rodrigo Vicentini What's a Dremel?
    30 Apr 2006
    fastening the hinges of the door:
    as it will be, it is very well hidden.
    I will use those buttons with magnet used in bags: D the door is well locked.
    fastening one of the parts in front of the case. and making some adjustments
    fastening the magnet in the door of the case, I glued him with acrylic:
  2. Rodrigo Vicentini
    30 Apr 2006
    open door and fastened:
    closed door and fastened:
  3. ledbythereaper
    ledbythereaper What's a Dremel?
    2 Jan 2007
    Thats some damn good molding work going on there, I think the skulls turned out just as good as the original
  4. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    that is some amazing work you have done there. 5* from me.
  5. Rodrigo Vicentini
    30 Apr 2006
    ledbythereaper, thank you for the comment, the skull was beautiful same (modest me hehehehe)
    500mph, thank you for the 5 *, I am happy that you have liked my work
  6. Rodrigo Vicentini
    30 Apr 2006
    I set up the case for seeing how it would be, but I noticed an unevenness between the front and the foot, then I put a piece of acrylic of 3mm to compensate this. after cutting I had to do some adjustments with acrylic resin to fit perfectly.
    everything finished and sanded, the holes of VUs also done already.
    I didn't like holes as they were, then I decided to tilt the angles, the result was good, taking into account that I made everything only with the dremel:
    Test with VUs in the places:
  7. Flixified
    Flixified What's a Dremel?
    8 Nov 2007
    Is it me or is the second hole along smaller than the others?
    Looking very good so far mate!
  8. Rodrigo Vicentini
    30 Apr 2006
    you are right, the second hole is smaller because there it goes is the place the power button, that will also be personalized. the first hole and for VU of HDD. thank you for the comment :rock:
    :dremel: some pictures of the front general vision:
    Cheapskate likes this.
  9. specofdust
    specofdust Banned
    26 Feb 2005
    Thread closed as per OP's request.
Thread Status:
