Electronics trigger circuit ???
Discussion in 'Modding' started by MoD, 25 Feb 2002.
  1. MoD
    MoD What's a Dremel?
    13 Oct 2001
    inspired from metku mods i decided to make a circuit which will look like a knight-rider kit when hdd led lights up. and in the middle will be a big led which will light up when the power is on. so whole thing will look like this:
    the problem is the circuit i found runs at 12V but the hdd header gives 3 volts :mad: i need some kinda trigger circuit which will give out 12volts taken from molex the light circuit when hdd header gives pulses. to explain it better i made a schematic:
    looking forward to hearing from you :D
    MasterOfDisaster :)
  2. linear
    linear Minimodder
    5 Oct 2001
    You want an optoisolator, and I thought japala had one in his schematic?
    It does exactly what you describe, plus provides total electrical isolation between your circuit and the mobo.
    Edit: ok, I see you're not building his circuit. USe an optoisolator:
    Pin 1 and 2 go to your HDD header, pin 3 no connection, pin 4 to ground, pin 5 to the - of your circuit's power supply, your circuit's power supply to +12 off the PSU, and pin 6 no connection.
    4N25 is a part number for a typical optoisolator, Maplin code AY44.
  3. MoD
    13 Oct 2001
    got the answer in 7 minutes :rofl: :rofl: liner thanks that was quick :D
    cheerz
    M0d
  4. linear
    linear Minimodder
    5 Oct 2001
    we aim to please.
  5. MoD
    13 Oct 2001
    linear sorry but being a total newbie to electronics i would like to ask 1 more thing. i made another diagram:
    did i get it right? probably not :confused:
    if not could you please draw sthg.
    i know i'm being a pain in the arse but pleeze help me :p
  6. linear
    linear Minimodder
    5 Oct 2001
    Close:
    Also note that your use of red and black on pins one and two kind of implies a polarity, which I think you have reversed. Pins 1 and 2 are connected to an LED inside the package, so it's polarity needs to be right for this to work.
    Also note my changes to the pin numbers, in red.
  7. MoD
    13 Oct 2001
    thank you very much linear
    cheers
    mod
