Electronics Tron Cyan LEDs Anyone?
Discussion in 'Modding' started by rupash88, 15 Mar 2011.
  1. rupash88
    rupash88 What's a Dremel?
    26 Nov 2007
    Just wondering if anybody out their knows where you can get Cyan colored LED's, or the color which is found throughout the new Tron movie. I'm note sure of its exact wavelength but I'm guessing to be around the 500nm mark. I can't find any in Ebay, the pic is of the color i'm after , something West coast customs did for a Tron themed R8, not sure what lighting they used thou.:eyebrow:
    http://autoflazh.com/the-tron-theme...coast-customs-–-more-blue-lights/tron_audi_2/
    Cheers,
  2. Shadow703793
    Shadow703793 What's a Dremel?
    5 May 2009
    Have you considered Emailing/Calling who ever did the R8? Usually, they are quite helpful and will sometimes even direct you to where you can get the items from.
    Worst case, buy one of every blue LED you can lay your hands on ;)
    Alternatively, you could try a RGB LED and see if you can get it to that color.
    mvagusta likes this.
  3. StonieX
    StonieX What's a Dremel?
    23 Dec 2003
    You could try some of them: Link
  4. Trance
    Trance Two steps forward, one step back
    6 May 2009
  5. rupash88
    26 Nov 2007
    Cheers, I'll give those sites a go.
