Ok I have a HDD from a ps2, and they attached metal rails to the side and used screws that need a bit that looks like this "*". Where can I get that type of bit, or is there any easier way around it. They seem to be on there fairly tight because I tried using a small flat head that fit, but it was slipping when trying to loosen. -Blake D.
Sounds like a Torx screw in which case you need a torx screwdriver (avalible from Automotive retailers ) Btw Some people call it 'stardrive' slater..
Plaggy pen, melt the end with fire! When its molten, stick it over it, let it set, you have a new screwdriver for it.
you have to be careful, does the screw have a pin looking thing in the middle? those are Torx security bits, and i beleive they are different than regular torx bits
Thats such a good idea im gonna have to do it in the mornin, theres a few things i wanna dismantle with those kinda screws . Death
