Trumpet Blowing 2019
Discussion in 'bit-tech Folding Team' started by Shirty, 27 Jul 2019.
  1. DocJonz
    DocJonz Another CPC refugee .....
    24 Apr 2009
    Shirty - you'll have to enlighten me - is that 1431W on one rig (which, at 53% load, would mean you have one uber PSU !), or is it the total load across your rigs as seen on a UPS?
  2. DocJonz
    24 Apr 2009
    Welcome to my world of electricity usage(!) - though 1431W is a bit lame in comparison :hehe:
  3. Shirty
    18 Apr 1982
    What do you reckon you're currently pulling from the wall? I'm guessing somewhere between 1550-1800W based off what I know of your setup(s).
    Budgeted an extra £200/month regardless, should cover it easily!
    EDIT: On an unrelated note, I reckon if the stars aligned on my current setup and each GPU got its optimal work unit, it would hit 9M ppd (or 11.5 if the gaming rig was folding too). As it stands I seem to be fluctuating between 7.5-8.5.
    The 2080Ti has been a mixed blessing. I have seen it vary from 1.55-2.75M ppd depending on project, a much bigger variance than any other card I've ever folded on. I can only assume that some projects are simply unable to leverage the power.
  4. DocJonz
    24 Apr 2009
    At the moment: on the 5 rigs Folding (the test machine won't be on for much longer) and the other 3 PCs running (but not Folding) - 2276W :brrr:
    (This is quite low compared to 2016, when I was using 110kWh of electricity per day and had 10 rigs Folding ...!!!)
  5. Shirty
    18 Apr 1982
    Yes, that is the definition of insane. I trust you have a favourable energy tariff...
    In other news, the stars aligned a little while ago. Got some much more valuable work units being crunched at the moment, I even briefly saw 9M pod!
    I usually get lumped with six 14180s, which are middling in terms of payout.
  6. Shirty
    18 Apr 1982
    Finally passed through the half-billion mark on the last update :rock:
    dark_avenger likes this.
  7. DocJonz
    24 Apr 2009
    Congratulations :thumb:
  8. Shirty
    18 Apr 1982
    Stats are FUBAR at the moment, always seems to happen just after I install new hardware too :rollingeyes:
    In other news, just cleared out the cupboard I've been shoving boxes in to as I've built up the folding rigs... box pr0n.
    EDIT: Just snuck inside the top 1000 on the last update. I mean, it'a a milestone of sorts.
  9. dark_avenger
    dark_avenger Minimodder
    9 Jul 2008
    Next update will put me in the 100mil club :rock:
  10. Shirty
    18 Apr 1982
    Good work. I've reached that break point, the no man's land between 690,000,000 and a billion. Be a few weeks before I see another climb up the charts.
  11. GeorgeStorm
    16 Dec 2008
    I've just noticed my output has been 0 for the past couple of weeks, haven't touched the folding PC and just see that it's on so assume it's fine. I wonder what happened, will have to check when I get in tonight!
  12. Shirty
    18 Apr 1982
    Nightmare! I have to keep checking in on my setup, I simply couldn't justify the expense of keeping this all running if I was getting failed WUs or stalled clients.
    There have been quite a few infrastructure issues/upgrades in the past few weeks, one of those may be at the root of your issue.
    It's well worth the time to bookmark your EOC page and check in once a day, or if you're more obsessive you can tinker with HFM.NET.
  13. DocJonz
    24 Apr 2009
    Nice job dark_avenger :thumb:
    I must be of the more 'obsessive' variety - as you are also of course :hehe:
  14. Shirty
    18 Apr 1982
    I think investing several thousand in hardware probably qualifies as obsessive (or just plain nuts), whether you use HFM or not :p:
  15. GeorgeStorm
    16 Dec 2008
    So turned on the monitor and unlocked the pc and it seemed to be sitting there waiting/failing to get a WU?
    Didn't have time to debug so just turned it off, better than wasting the power, but hopefully I'll try to have a look at it soon, as won't be able to keep doing it much longer (meant to have sold the 2080ti August/September haha)
  16. DocJonz
    24 Apr 2009
    F@H had a server glitch in the recent past (at Temple University) which was causing new WUs to fail to download correctly, causing rigs to hang - I had loads of issues when it happened(!) I expect you may have been hit by the same issue.
  17. RedFlames
    23 Apr 2009
    *takes breath*
    *blows trumpet*
    *makes no noise*
    My first WU in a while will complete in a few hours...
    ...it's something I guess.
  18. Shirty
    18 Apr 1982
  19. RedFlames
    23 Apr 2009
    You say that now... but the client is crashing left, right and centre... Also cpu only so...
  20. Shirty
    18 Apr 1982
    Just passed the billion mark, although EOC will have to wait until 3pm to reflect this...
    :clap:
    Big Elf likes this.
