News TrustedReviews acquired by IPC Media
Discussion in 'Article Discussion' started by Tim S, 22 Oct 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. will.
    will. A motorbike of jealousy!
    2 Mar 2005
    Good luck!
  3. Guest-23315
    Guest-23315 Guest
    As long as nothing changes, then thats good news!
  4. Orca
    Orca What's a Dremel?
    2 Dec 2005
    Best of luck to TR. Now onwards with the world domination BT :D
  5. Lazlow
    Lazlow I have a dremel.
    8 Aug 2003
    Does this mean Bit-tech will inherit all of the Trusted reviews office space?
  6. DougEdey
    5 Jul 2005
    All I can say is Bye Bye RTT as bit developer.
    We may miss your coding.
  7. RTT
    RTT #parp
    12 Mar 2001
    I've (sadly) not worked for, or on, bit-tech since mid 2005 - TR have owned me since then :) I don't think that has been known to you regulars until now ;) Jamie is super super elite, so there's nothing to worry about on that front :D
  8. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Lets hope you don't go under.
  9. Tim S
    Tim S OG
    8 Nov 2001
    That's one thing that I'm sure is not going to happen :)
  10. cosmic
    cosmic What's a Dremel?
    6 Jul 2007
    You ave done agreat job on both sites RTT
  11. DougEdey
    5 Jul 2005
    What was with that little portal thing then.
    And you looked at that sendmail script so ner :p
  12. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
    No, the opposite. We'll be moving offices ourselves.
  13. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    Where are you guys moving then?
  14. Tim S
    Tim S OG
    8 Nov 2001
    We're not moving anywhere for a while... it'll be sometime in the next few months. :)
  15. DougEdey
    5 Jul 2005
    Come to boro, it's regenerating don'tcha know. And will help to get us off the bottom :D
  16. Tim S
    Tim S OG
    8 Nov 2001
    heh, I'm fairly sure we'll be staying "in the area".
  17. CardJoe
    3 Apr 2007
    We'd better be - I only just moved down here! :p
  18. Hugo
    Hugo Ex-TrustedReviews Staff
    25 Dec 2006
    Yeah, I just moved down to start working for TR, buggered if I'm relocating again (unless it's to London, I'd move to London)
  19. Guest-23315
    Guest-23315 Guest
    BT, move to Windsor
  20. ArtificialHero
    ArtificialHero We were just punking him sir!
    25 May 2004
    Windsor is a rather expensive place to base a business, which is why no one bothers ('cept for shops, and that). I *did* see some nice new offices for rent when I passed through Bourne End the other day though - not too far from Bracknell, and Bourne End is a much nicer setting. Edit: nicer than Bracknell, not nicer than Windsor.
    AH
Tags: Add Tags
