Trying out Vista.. Very slow.
Discussion in 'Tech Support' started by Sam0r, 11 Aug 2007.
  1. Sam0r
    Sam0r It's been a while
    24 Jun 2005
    Right.. I finally decided to try vista.
    So, I backup my XP-64 partition and install Vista-64.
    After vista installed, I installed all updates except the microsoft gfx drivers and the motherboard drivers.
    Once installed and rebooted, I installed the Nforce 4 drivers and the latest Nvidia gfx drivers.
    But for some reason, Vista is amazingly slow. So slow that moving windows around lagged like crazy.
    I also installed that performance and reliability pack, it didn't make a difference.
    I had a small LAN party on friday, and I managed to play with vista on my friends machine which had an Athlon 64 3200+ @ 2.6ghz, 2gb ram and a geforce 7800GT 256mb. It ran perfectly fine on his PC, much much much faster than on mine!
    My system spec is as follows:
    Asus A8N32 SLI Deluxe
    AMD Athlon 64 x2 3800+ @ 3ghz (Stable)
    4gb DDR Ram (Running at 200mhz)
    Geforce 6800GT 256mb
    Seagate Barracuda 250gb SATA II HDD with 16mb Cache
    I've also tried vista with the processor at stock, and still it runs slowly.
    Has anyone else experienced this?
  2. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    Yep vista is very hungry and not worth using.
  3. Sam0r
    24 Jun 2005
    Yeahh..
    Anyone else? :sigh:
  4. Fophillips
    Fophillips What's a Dremel?
    9 Oct 2006
    I found Vista sluggish, but not this bad...
  5. Sam0r
    24 Jun 2005
    Well, on my friends PC, it runs just like XP does. Really smooth and quick.. I was really surprised considering what some people have been saying about it.
  6. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    I notice your friend has a better video card than you do. Try turning off some of the visual junk thats in vista and see if that improves it any.
    Also, was this a clean install of vista or an upgrade install from xp?
  7. Sam0r
    24 Jun 2005
    It was a completely clean install. I remember using vista on an old Pentium 4 1.8ghz box with 512mb ram and a Geforce 5900 and it was no where near as slow as my pc when running vista.
    I might try it again later and install the drivers before I install any updates.
  8. Nexxo
    23 Oct 2001
    It should manage just fine. But your complaints suggest to me a graphic card driver issue. Roll back to the previous version and see if that helps.
  9. Sam0r
    24 Jun 2005
    Yeah, I was thinking that. I'll download these and see how it goes.
  10. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    I was going to post saying it's the indexer and such, but it doesn't seem so. You have a very similar system to mine, so I'd probably say it was a driver problem.
  11. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
    sure its not your hdd ? Whats your activity lights doing ? could be that you partitoned at the end of the drive = slower r/w speeds ?
    Just a thought...
  12. DougEdey
    5 Jul 2005
    Defraged?
  13. chrisb2e9
    18 Jun 2007
    a fragmented drive wouldn't cause trouble when just moving a window around the desktop.
    Like someone else said, its sounding like a driver issue. Let us know how the latest drivers work out.
  14. capnPedro
    11 Apr 2007
    Right click -> properties on My Computer
    Click on Windows Experience Index
    Click Update my score
    And then tell me your scores ;)
  15. Sam0r
    24 Jun 2005
    I've just gotten vista installed. I'm currently installing drivers, albeit slowly...
    Edit 1:
    Ok, Drivers installed now.
    Its still very slow, CPU usage is only at about 5% to 20%. I've installed no updates yet though.
    I'm getting loads of GUI corruption and the GUI seems pretty unresponsive. Moving the cursor over buttons on the start menu, they don't seem to react to the cursor until the cursor is on a button three buttons away.. if you understand what I mean..
    Say If I'm moving from button 1 to 10. Once I've hovered over button 3, button 1 will react.
    I'm thinking the graphics card might be over heating, although I was playing COD2 and all sorts on this machine last night with no problems what so ever.
    Edit 2:
    Ok.. I've tried to take a screenshot of the corruption, but it just comes out blank. I'm going to install Rivatuner and see if there's anything I can change regarding fan settings..
    Also, the scores:
    Index: 5.0
    Processor: 5.4
    Memory: 5.0
    Graphics 5.9
    Gaming Graphics 5.4
    HDD: 5.7
  16. Gravemind123
    Gravemind123 avatar not found
    26 Aug 2006
    That seems low for the memory score, this article over at Tom's Hardware shows that 2GB of DDR2-667 in dual-channel getting 5.5 for its Vista rating. I'm not sure if this can help find your issue, but it is an odd too have such a low score for 4GB of ram.
  17. Sam0r
    24 Jun 2005
    Hmm.. This is odd.
    I'm running with 3gb of ram in at the moment, and everything is running perfectly.
    Its VERY snappy..
    I'm confused.
    Edit:
    I've also just refreshed the ratings, the ram score hasn't changed.
  18. chrisb2e9
    18 Jun 2007
    running with 3gb? so you took a stick out?
    that is kind of strange. I'm at a loss, you didn't change anything in the bios did you? maybe the timings or voltage need to be adjusted?
  19. Sam0r
    24 Jun 2005
    Sorry, no. I haven't taken a stick out. I told Vista to only use 3gb of RAM. So the memory is still there, its just that Vista isn't using it.
    This is very very weird, XP64 worked perfectly fine, but Vista is crapping its self over it!
  20. DougEdey
    5 Jul 2005
    Does the BIOS have any kind of RAM address mapping option for 4GB? If so enable/disable it.
