Trying out Vista.. Very slow.
Discussion in 'Tech Support' started by Sam0r, 11 Aug 2007.
  1. Nexxo
    23 Oct 2001
    DougEdey is on to something, actually. In theory 32-bit OS's can address all 4 Gb but for a range of complex technical reasons don't; instead the fourth 1 Gb part of the address map is reserved for various PCI hardware and the fourth 1 Gb RAM shunted further up the address map. In short:
    Code:
    Address Contents
    0x00000000 - 0x3fffffff Memory
    0x40000000 - 0x7fffffff More memory
    0x80000000 - 0xbfffffff Even more memory
    0xc0000000 - 0xffffffff Memory-mapped devices
    0x100000000-0x3ffffffff Where the *?#! did my last GB go?
    To accommodate this, some motherboards have options of getting around that in their BIOS to access that last 1 Gb of memory. In your case, it may confuse Vista no end.
  2. Sam0r
    Sam0r It's been a while
    24 Jun 2005
    Well, for my motherboard to "see" all 4gb of ram I have to turn on the hardawre memory hole option. With it off, the bios and OS only see 3gb. But surely that shouldn't matter if I'm using a 64-bit OS which can address much more memory locations?
  3. DougEdey
    5 Jul 2005
    It's not just the OS. It's also a problem within the BIOS that hasn't really been addressed properly. What used to happen on older boards (to disguise this) was that you would have 4 slots but could only use a maximum of 3GB, or 3 slots with a maximum of 4GB. Not 100% sure why this happens but my friend had a similar problem and found that if he dual booted he would have the memory hole off for XP and the opposite for Vista
  4. Sam0r
    24 Jun 2005
    Ah right, I thought that too earlier. Even though the manual says 4gb max, maybe thats not the best option.
    I might give asus a call.
