Other Trying to find 4pin fan cable spool
Discussion in 'Hardware' started by LT.BEECH, 4 Nov 2021.
  1. LT.BEECH
    LT.BEECH Minimodder
    23 Apr 2009
    Hi, as the title says I am trying to find a spool of the 4 pin fan cable. It is easy to find the 22 awg cable as a single wire I am just wondering if anyone knows where to get some. I would rather make a custom length cable instead of using more connectors.
    for reference I am connecting 3 arctic P12 fans to a single fan connector as the Gigabyte B550 I only has two, but they are too short in my Phanteks shift X. The fans are good as they include a daisy chain connector on each fan, but I would rather clean up the mess while I am at it.
  2. David
    7 Apr 2009
    You can buy 22awg ribbons
  3. LT.BEECH
    LT.BEECH Minimodder
    23 Apr 2009
    Yes you can, I am trying to find it in black within the UK.
