Motherboards Trying to identify Mobo
Discussion in 'Hardware' started by Kronos, 10 Jun 2011.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
  2. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Have you tried CPU-Z to ID the mobo.
  3. Zehetmayr
    Zehetmayr Minimodder
    23 Apr 2011
  4. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Open it up, there's usually some product numbers floating around that if you google may reveal stuff to you :)
    Are you looking for the specific motherboard name or just specs? As Mr Bag says, CPU-Z will give you the chipset info and such easily.
  5. Kronos
    Kronos Multimodder
    6 Nov 2009
    Sorry guys the PC was knackered, I have remove the mobo. So no to software. Not much in the way of product numbers either.
  6. Bloody_Pete
    11 Aug 2008
    For OEM boards, it's unlikely there will be a manual, but that link you gave us gives alot of the specs...
  7. Kronos
    Kronos Multimodder
    6 Nov 2009
    Ita a UWave2 board, so getting closer.
  8. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    As with many oem, they seemed to have used at least 3 different motherboards for that model number. There will be at least a part number on it somewhere, which will be your only hope of identifying it if you're looking for an exact replacement or something.
  9. Kronos
    Kronos Multimodder
    6 Nov 2009
    Not so much a replacement, just a manual. The board works OK,just it has some odd connections which I would like to identify. No big deal really, I very much doubt if I could flog something as ancient as this.
  10. IvanIvanovich
    31 Aug 2008
    Perhaps just posting a pic of what you want identified would be easier? Or if you don't have that ability a detailed description of the connection, shape, amount of pins, etc.
  11. faugusztin
    11 Aug 2008
    ^ exactly.
  12. confusis
    confusis Kiwi-modder
    5 Jan 2006
