News TSMC 16nm to hit volume production this year
Discussion in 'Article Discussion' started by Meanmotion, 17 Jan 2014.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. Alecto
    Alecto Minimodder
    20 Apr 2012
    "It will be the highest performance technology amongst all available 16 and 14nm technologies in 2014. This progress is well ahead of Samsung," Liu boasted.
    How does that relate to Intel's 14 nm process (to be used for Broadwell)?
  3. rollo
    rollo Modder
    16 May 2008
    No clue, Rumours around though that Apple paid mega bucks to buy out alot of the early production.
    Maxwell will likely be the first gpu released under the process.
  4. fluxtatic
    fluxtatic What's a Dremel?
    25 Aug 2010
    Eh...I'm not buying it. They're just now ramping up production of 20nm, and they expect us to believe they're jumping right to 16nm for volume production this year?
  5. Guest-16
    Guest-16 Guest
    I've heard and read their process' vary between "14-20nm". I'm not sure the specifics as TSMC itself is very tight with real info.
  6. Eriol
    Eriol What's a Dremel?
    8 May 2011
    AFAIK 16 nm FinFET isn't actually 16 nm, but just 20 nm with FinFET. It's actually on a similar level with Intel's 22 nm Tri-Gate. Intel is way ahead in the process tech game.
    If you're a pessimist it seems like 16 nm FinFet is the first process you'll get any decent benefit over the current 28 nm as far as GPU's are concerned. And if the first production is SoC only and we'll have to wait until late 2015 before getting it in GPUs we're in for a long wait before we see anything better than the 780 Ti.
  7. Guest-16
    Guest-16 Guest
    That's the one! :clap:
    +rep you.
    And yes - there's a process difference between making tiny ARM chips and ~10Bn transistor GPUs.
    EDIT: Rep button disappeared??
Tags: Add Tags
