Modding TT Shark Window Mod! Front mesh update
Discussion in 'Modding' started by Defyant Mods, 19 Jun 2005.
  1. Krog_Mod
    Krog_Mod What's a Dremel?
    23 Sep 2003
    Dear God! This is some of the best looking modding i've seen since ZapWizards AmmoPC. You have good taste. Keep up the good work!
  2. GigantoR
    GigantoR What's a Dremel?
    21 Jul 2004
    That is gonna look great when you get the new mesh to match the mesh on the window panel. Have one idea maybe.
    That bottom intake would look really nice if it was removed and meshed as well.
  3. moddenmania
    moddenmania What's a Dremel?
    18 Sep 2004
    i agree with GigantoR
  4. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Helluva improvement Defyant! :thumb:
  5. leviathan18
    leviathan18 What's a Dremel?
    17 Mar 2005
    super nice mod a friend says you are great, i had an idea should be nice if you give to the case the same finish as the wavemaster all chrome
  6. Zekey
    Zekey What's a Dremel?
    10 May 2005
    Seconded.
    Really, crazy amazing job.
  7. XplicitContent
    XplicitContent What's a Dremel?
    12 Mar 2005
    It is a good job, and if I havent misread, your going to put the same hexigonal modders mesh from the side to the front to make them match correct? Then I dont understand the point of doing this with the circular modders mesh then?
    Other than that, it is a good job, kind of stole my ideas I was going to use, but you got to it first as I dont have a dremel yet. But of course, no one can match up to my other modding to the Thermaltake Shark as I can, and it will be soon till you all see it! Mwahahahaha!
  8. Machine
    Machine What's a Dremel?
    27 May 2004
    dude!, that`s some outstanding mod :rock: keep on modding!
    This shuldo go to mod projects IMO :baby:
    this deserves 5 !
  9. ou7blaze
    ou7blaze sensational.
    5 May 2003
    Looks very nice and professional.
    Solid modding skills there :rock:
    That case actually looks really ... sleek and stylish now good job
  10. djedditt
    djedditt What's a Dremel?
    18 Aug 2004
    Very nice done.. :thumb: How's that mesh called you used for the front?
  11. dibek
    dibek What's a Dremel?
    12 Jun 2005
    It's called moddersmesh. You can buy it over at www.mnpctech.com
    BTW very nice modding. I also think you should match the front and side mesh, but IMO you should go with the circular mesh.
    You should also paint the interior as it looks kinda funky like it is :)
    I've done some simmilar modding to my TT tsunami, although not so rigorous :) . I've cut the fan grilles, cut the inner (plastic) door and i also did a blowhole on top.
    Maybe i'll post some pics soon.
  12. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    nice ideas
  13. Ryszvaldo
    Ryszvaldo Banned
    3 Jan 2005
    Looks superb! Really well done!
