Hardware Tuniq Tower 120
Discussion in 'Article Discussion' started by CardJoe, 1 Nov 2007.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. Guest-23315
    Guest-23315 Guest
    Very formative review for just one heatsink...
  3. Hells_Bliss
    Hells_Bliss What's a Dremel?
    6 Apr 2007
    link points to mozilla article...
  4. Guest-16
    Guest-16 Guest
    Ta, fixed :D
  5. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    Does it come in green, red and blue varieties?
  6. CardJoe
    3 Apr 2007
    :duh:
  7. Major
    Major Guest
    My first thoughts where...
    Where is the Thermalright Ultras? :)
  8. drakanious
    drakanious What's a Dremel?
    12 Apr 2007
    "Where is the Thermalright Ultras? :)"
    I'd like to see a REAL review of the Thermalright FX-14--I've only been able to find 2 reviews, and they're both in German (I can read German, actually, but I don't know if I can trust the sites.)
  9. Kahuna513
    Kahuna513 What's a Dremel?
    1 Nov 2007
    Although informative, you spend far too long going on about how hard it is to thread a few wires through a slot 25mm thick, yet you fail to mention how it's impossible to mount with the correct sideways orientation on some motherboards [MSI nForce 4, anyone?], bends capacitors on others [Asus P5n SLi] and how the base plate is so large it has a tendency to cover any small electronics surrounding the CPU socket, let alone the fact that it's almost impossible to take the PSU out without removing the tower if you happen to own a smaller sized ATX case.
    Oh, and the thumb screws break if you're not careful.
    Saying that, I've come across all of the above issues and don't care =)
    Just a heads up.
  10. wyx087
    15 Aug 2007
    hum..... i was going to upgrade to this because my Zalman 9500 LED can't keep my 3.2Ghz overclocked q6600 cool below 60c :(
    would this be able to do it? or do i need something better? (aka the best) Thermalright Ultra 120 Extreme?
  11. Jipa
    5 Feb 2004
    Nice review.. The only problem being THIS AIN'T THE 8800GT REVIEW EVERYONE'S WAITING! What's taking so long, hasn't there been enough whipping?
  12. bluep3ace
    bluep3ace What's a Dremel?
    12 Nov 2006
    great review...only a year late...
  13. Guest-16
    Guest-16 Guest
    I hadn't thought of that. It mounted just fine on the range of recent motherboards I had to hand!?
    And it maybe a year late, but people asked how it compared so we did it :p
    The thumb screws are meaty brass jobbies! They shouldn't break. And the size issue is the same with almost every aftermarket cooler these days :)
    We do have a Thermalright in, maybe I'll do it next week given time.
  14. Jodiuh
    Jodiuh What's a Dremel?
    17 Mar 2006
    I'm not sure what happened in your review, but I've found the Tuniq to be one of the best HSF's around. Great mount, quiet, killer performance.
  15. BigD79
    BigD79 Gadding about...
    2 Nov 2007
    pmsl!!
  16. Guest-16
    Guest-16 Guest
    How many other heatsinks have you used? :) Everything is comparative and some people have a greater tolerance to noise or have a more insulated case etc. The mount is good - I liked it, but as said above ^^ some people found incompatibilities I didn't. Some other sites liked it more, but that's the benefit of consumer choice and alternative points of view :) If you like it, then fair enough :thumb: Better that then to read a review that says it's good and find you don't like it :p
    Jipa - my arm got tired :'(
  17. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    I've used the TT, SI, and Freezer 7 pro.
    Freezer was most user friendly and best bng for buck....but overall I'd pick the Scyth Infinity out of the lot, been great..............although I do wish all coolers would use the TT mounting bracket as I hate the pushpins.
  18. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    I have one, bought it before this review. Saddly it's just too loud for me - though the case it's in is bad for noise anyway (I just haven't made time to move it - though maybe I'll use some ducting instead.)
  19. impar
    impar Minimodder
    24 Nov 2006
    Greetings!
    The TRUE120 is currently the king of heatsinks. If you can, go for it.
  20. Dreaming
    Dreaming What's a Dremel?
    31 Jan 2007
    Really?
    I hated my Scythe Infinity for several reasons. It did have awesome cooling performance, but on balance I find the Freezer 7 much better. When the Infinity fell off when I was moving my case that was it - I placed the order on scan the same day. I'm not going to risk trashing a £200 graphics card because they gave me plastic pushpins (that you can't reach cos the bottom fins are so low), for the sake of a bit better cooling.
    But like the reviewer said everyone has their own take on these things. I actually like the look of the tuniq tower as it has a proper mounting solution.
Tags: Add Tags
