Guide Turbine Mod & Install Video Guide
Discussion in 'Modding' started by mnpctech, 7 Sep 2007.
  1. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    This video has been requested for a long time.
    Let me know what you think! :D
    Part 1: I describe an old beige case I found and demonstrate the tools and products neccessary to mod and paint your case with a Turbine style front intake. You'll learn how I install a front fan duct in a bezel and apply body filler (Evercoat brand)
    Part 2: I show you how to sand the body filler with a Mouse Sander so it's ready for paint. I then walk you through the steps in painting the bezel and case panels with "Plastikote" brand "Engine Enamel" spray paint.
    Part 1
    Part 2
  2. Supra55
    Supra55 What's a Dremel?
    10 Oct 2006
    Finally! Love the mod thanks allot for it :thumb: Oh and BTW what hole saw size are you using?
  3. Ryu_ookami
    Ryu_ookami I write therefore I suffer.
    11 Mar 2004
    cool I'm at present grabbing all your videos for in case I lose my internet connection. I do have one quick question in your case mod basic window install you mention the type of blades you use with your jigsaw but I didn't couldn't hear the type could you say what they are here please thanks :)
  4. sik19
    sik19 What's a Dremel?
    2 Jan 2006
    Thats a real great Tutorial. I really like your Case Mod Basics Video Series.
  5. ComputerKing
    8 Sep 2006
    WOW! I love this, I put it on my bookmark :D huaha ":D Thanks alot buddy :D take care.
  6. capnPedro
    11 Apr 2007
    Excellent work (as always), Bill. I've been a fan (hehe) of this mod for a long time.
    Oh, and "Behold, the power of [ youtube ] tags!"
    removed video dupe
    Also, way to go posting this here, while it's still "coming soon" on your site. :brrr:
  7. mnpctech
    21 Apr 2003
    Thank you capn! fixed the links :D
    Great! It's a 4.5 size hole saw
    Use at least "18 TPI" size jigsaw blade for cutting metal & plastic (TPI = Teeth per inch)
  8. perkins teh modder
    perkins teh modder What's a Dremel?
    8 Dec 2007
    definitely gonna use this, thanks bill!!!
  9. mnpctech
    21 Apr 2003
    You bet! Look 4ward to seeing your turbine mod creation :dremel:
  10. badders
    badders Neuken in de Keuken
    4 Dec 2007
    That's awesome.
    I felt a little sorry for the Beige case though when you said "Don't Worry, it's not gonna be beige!"
    You should have done the mod and re-painted it beige for that "factory Overclocked" look!
  11. perkins teh modder
    8 Dec 2007
    one thing, does any1 no where i can find a shea technologies case for $20?
    and bill, do you know if the MidTower ET3890A case on your video tutorial can fit a 120mm and a 92mm on the bezel? or two 92mm fans?
  12. Teknokid
    Teknokid Minimodder
    6 Dec 2007
  13. mnpctech
    21 Apr 2003
    Yes, we were thinking of building a total sleeper Gaming Rig in Beige sometime :hehe:
    I installed a 120mm fan in the chassis with an air duct mounted in the bezel, theres not enuf space for a fan to be sandwiched between the bezel and chassis, if thats what you're asking?
  14. nexuspctech
    nexuspctech What's a Dremel?
    8 Sep 2008
    Very nice videos, they will help alot of people.
  15. whodareswins89
    whodareswins89 What's a Dremel?
    14 Sep 2008
    So helpful! Thanks!
  16. mnpctech
    21 Apr 2003
    Thanks for the comments! I'll keep making these guides when I can :thumb:
