Motors Turbo possibly not working
Discussion in 'General' started by silentriver, 29 May 2005.
  1. silentriver
    silentriver New Member
    20 Apr 2004
    I helped my mum get a car yesterday, similar to mine - same engine a 1.7 td isuzu engine vauxhall astra.
    Our is an older model but the engine is good and powerful. I let my mum test drive it and we looked at the engine which didnt look as good as ours. But it drove fine so my mum took it. We went back later that night and i drove it home, having the same car i knew the engine, the turbo does not seem to be kicking in. Have i helped my mum buy a lemon or is it a fixable thing, it does need a service and im hoping this will help sort it.
    :rolleyes:
  2. TwiSteD LoGic
    TwiSteD LoGic New Member
    1 Nov 2001
    Well I guess the first question is what do you mean by "kicking in"?
    Can you hear the turbo spooling?
  3. mUrml
    mUrml New Member
    13 Jan 2005
    If the turbo is running, but you aren't getting any "boost", it may be the wastegate not working probably. But it's pretty hard to tell over the internet whats wrong with it.
    But everything is fixable :), ofcourse for the right price that is.
  4. ufk
    ufk Licenced Fool
    3 Jan 2004
    you could try asking over @ http://www.cavweb-forums.co.uk/ , they know all the ins and outs of the vauxhall engines and will probably know the answer off the cuff. I've got a cavilier with the izusu lump and they helped me out loads when the bugger packed up
  5. silentriver
    20 Apr 2004
    Thanks for that i'll have a look
  6. deadly-app
    deadly-app New Member
    9 Mar 2004
    Well first off, if it wasnt running period(ie it froze) then your engine would get no air and seize up and die. So obviously it is working somewhat. Now, the wastegate might be stuck open somewhat and letting most of the air escape, but it is still getting air to the engine.
    Do you hear it spool up? It should still spool up when you mash the accelerator...
  7. penski
    penski BodMod
    29 Aug 2002
    No it wouldn't. The turbine blades may not spin but air will still flow through it.
    Most likely, it has a recirculating wastegate - excess charge is released back into the system. This does not apply here.
    *n
  8. deadly-app
    9 Mar 2004
    how would air still flow through it? The turbine is fairly well fitting to the casing I assume, so it would be a very very small amount of air entering...which probably wouldnt be enough....
    Ah, yes I forgot about recirculating wastegate. The air is just re-entering the intake, but hes not going to get the boost. The engine will take what it needs and no extra because it will flow out the wastegate.
  9. TwiSteD LoGic
    1 Nov 2001
    I have driven a car with a seized turbo in it, and it still ran. It definatly didnt run properly that is for sure, but it did run. I would bet I was running very rich, but I only drove it like 30 miles (to and from work until I had time to get under the hood).
    Penski, whats up with my sig?
  10. deadly-app
    9 Mar 2004
    So i was partially right, partially wrong. I didn't believe that you could get enough air in there through siezed turbos ;)
