TurboV for Windows 10
Discussion in 'Asus UK' started by giskard, 20 Apr 2016.
  1. giskard
    giskard System builder
    21 Nov 2009
    I've upgraded from Win7 to Win10 but there's no Asus TurboV application that I can find will install to Windows 10. Is there a Windows 10 version available?
  2. TheMadDutchDude
    23 Aug 2013
    Just install the Windows 7 version. If that doesn't work and a Windows 8/8.1 version is available, install that.
  3. giskard
    21 Nov 2009
    I tried both those options but the installer says that the OS is incompatible and exits.
  4. TheMadDutchDude
    23 Aug 2013
    How strange. I'll try to install it here and see if it does the same thing.
  5. giskard
    21 Nov 2009
    Thanks, much appreciated :)
  6. wormy
    wormy Member
    16 Oct 2009
    I've had the same, on a different board, and had no luck trying to install the W7 version but didn't yet try the 8 version.
  7. TheMadDutchDude
    23 Aug 2013
    I forgot to get back to you on this ... I had the same issue. :(
