Motors Turning computer chair around with a motor?
Discussion in 'General' started by Weekly_Estimate, 21 Apr 2016.
  1. Rhydian
    Rhydian What's a Dremel?
    13 Nov 2010
    why though?
    Tbh you'll be much better off strapping a hyabusa 1300cc motor to it and going all out and spinning the crabs out of the daring.
  2. walle
    walle Minimodder
    5 Jul 2006
    You gotta love the English, so damn eccentric.
    Stop the madness! :D
  3. Xlog
    Xlog Minimodder
    16 Dec 2006
    Or you could also go pneumatic. I wonder how many rotations you would get out of 11L scuba tank:rolleyes:.
  4. David
    7 Apr 2009
    Slot a large cog over the central support pole (welding or a keyway may be required) and run a wormwheel directly from a DC motor.
    You can probably control the motor via Arduino.
  5. bawjaws
    bawjaws Multimodder
    5 Dec 2010
  6. legoman
    legoman breaker of things
    28 Feb 2010
    Wheelchair motor perhaps? Pretty easy to get hold of as would a power pack from one
  7. Vault-Tec
    30 Aug 2015
    Pics and videos or it didn't happen !
  8. Rhydian
    13 Nov 2010
    I still persist on asking why?
    But I had an idea. Why not a lot implement a screw lift. So it swivels and rises. For even more fuN! Heck got the whole way and make it dual action.
  9. GeorgeK
    18 Sep 2010
    Please this - let's all agree to only give any more suggestions and / or advice on the condition that OP videos (a) building the motorised whirly chair-of-death and (b) the first test run (which has to be with him sat in it) :hehe:
  10. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    Since the OP has ignored all requests for information, I'm assuming it must be for some strange sexy times thing. :eeek::jawdrop:
  11. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    It's not a chair, the mechanism is to rotate something, but I doubt it's a chair. Possibly involves a tube though. :hehe:
  12. GeorgeK
    18 Sep 2010
    Haha
  13. David
    7 Apr 2009
    All it needs is a sharp point fixed to a nearby wall, and we have our first human Spiralizer.
  14. Weekly_Estimate
    Weekly_Estimate Gives credit where its due
    1 Feb 2010
    I was thinking about building a solid frame at the bottom of the chair housing the motor however this isn’t possible because when it starts spinning my legs either have to go else we need to go down another route.
    So the solution would be to drill some holes through that tube we welded to the bottom of the chair build a frame supported by that tube then have the motor turning with the chair (with a long cable)?
    We also need to put some teeth on the tube so that the chain can connect to the chair.
    What worries me though is how strong are welds and will the tube be able to support a frame/motor which weighs quite a bit.
    When i’m home later i’ll jump into photoshop and make a mock up
  15. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    That's really really really interesting.....but WHAT ARE YOU DOING WITH THIS ROTATING CHAIR!?!11?! :D
  16. Weekly_Estimate
    1 Feb 2010
    I thought i answered this in another comment but i intend to connect it to the internets for the world to control :) I do have a master plan but that’s irrelevant until we get this chair made.
  17. Flibblebot
    19 Apr 2005
    If it's going to be interweb connected, you may want some kind of audio alert to give you time to lift your feet!
  18. Weekly_Estimate
    1 Feb 2010
    So i made a 2 minute mockup using photoshop, which shows what i’m aiming for, currently in discussion with the motor supplier on adjustments for speed and range and if it comes back it can be adjusted that’s the big issue sorted! :)
    instead of using a button presser i wonder if we can somehow use a script to send the wireless signal to the lift :p
  19. Mr_Mistoffelees
    Mr_Mistoffelees The Rotary Cat.
    26 Aug 2014
    That's no good, too high revving with all the grunt near the top end. I would suggest a Tesla Model S motor, loads of torque from standstill, will spin him up nicely!
  20. Shirty
    18 Apr 1982
    1. Make high-speed rotating chair to be triggered by "the Internet".
    2. Forget to invest in wireless headset.
    3. ?????
    4. Profit Die
    I can see no issue with this harebrained idea!
