Windows Turning Off Anti-Aliasing In PS7?
Discussion in 'Software' started by mookboy, 8 Sep 2003.
  1. mookboy
    mookboy BRAAAAAAP
    15 Feb 2002
    Anyone tell me how to? I'm trying to follow a tutorial in creating pixel art and I'm struggling to locate the option. Gah! :wallbash:
  2. bradford010
    bradford010 Bradon Frohman
    7 Dec 2001
    What tool are you trying to draw with?
  3. mookboy
    mookboy BRAAAAAAP
    15 Feb 2002
    Pencil and the line shape tool.
  4. Mister_Tad
    27 Dec 2002
    there is an antialiasing tick-box in the tool option bar with most tools
  5. bradford010
    7 Dec 2001
    With marquee tools, yes, but not really with brush/pencil/paint tools.
    With the line tool, I think it's unavoidable (I'd be happy for someone to tell me otherwise).
    With the pencil, are you sure you've got it down to 1px, normal mode at 100% opacity?
    If you have, and it's still applying anti-aliasing, try loading the square brushes palette and go down to a 1px wide brush with that.
  6. mookboy
    mookboy BRAAAAAAP
    15 Feb 2002
    Specifically the line shape tool. When I draw for instance a cube with it and then fill the surfaces, it leaves a tiny white line round the edges ruining the effect. I know it can be turned off because the various tutorials say so, however I cant seem to locate the option!
  7. Alaric
    Alaric code assassin
    3 Nov 2001
    ok then,
    There is a box to enable/disable anti-aliasing if on the line tool you select the 'fill pixel' option for it (the right hand box of the second tool group from left. Not have it as making a shape/path. Then instead of stuff for dealing with shapes and the target layers there'll be a bit for opacity and antialiasing.
    Sorry if the descriptions are a little vague, i can take screenshots if you need any more guidance. (makesure you also turn off AA with the fill tool when you are doing it btw.)
    Hope that helps
    Alaric.
  8. mookboy
    mookboy BRAAAAAAP
    15 Feb 2002
    I love you. :clap: :clap:
  9. bradford010
    7 Dec 2001
    I stand corrected :)
