Notebooks Turning Touchpad back on
Discussion in 'Tech Support' started by Freemanator, 4 Oct 2009.
  1. Freemanator
    Freemanator New Member
    13 Sep 2005
    Hi Guys,
    I was wondering if anyone could help me.
    While at Uni my main PC was a laptop but as I used an external mouse with it, I disabled the touchpad. Now I can't for the life of me find how to re enable it so I can use my external mouse with my desktop, but still use the laptop so I can finish handing over files. Can anyone help?
    If it makes a difference I have an Evehsam Voyager C720, and the touch pad is an Elantech one.
    Thanks in advance,
  2. thehippoz
    thehippoz New Member
    19 Dec 2008
    isn't it under the control panel > mouse
  3. Freemanator
    13 Sep 2005
    I don't think so as I have looked at all the options there. I should also say I am running XP.
  4. xprodancer
    xprodancer life is like a box of chocolates
    24 Jul 2009
    does it have an icon next to the clock (bottom right hand corner) if so can you right click and enable device??? or you can try to go into the device manager finding the device and do the same right click > properties > enable device!
    try those????
  5. B3CK
    B3CK New Member
    14 Jun 2004
    Are you sure none of the keys have a 'FN+' "pad" ?
    Also look around the outside edge of the pad, no button elegantly hidden there?
