Guide <- TUTORIAL -> How to invert an LCD Screen !!
Discussion in 'Modding' started by samtech, 26 Dec 2002.
  1. samtech
    samtech What's a Dremel?
    26 Dec 2002
    Well first of all, i've been away some time from the modding due to studying, as for the LCD to control it you can use:
    http://www.lcdstudio.com/e107/news.php
    or the original page that has a wiring diagram for KS0108 compatible LCD's
    http://skippari.net/lcd/ks0108.html
    the LCD i have has some diferent pin-outs , butthe control pins are the same , if you need i can upload the fulll datasheet to my web space , s it need for th Led backlight a 20 Volt tension and a -20 volt tension for the contrast adjustment.
    For the questions placed about the polarizing film , you have to unglue it from the LCD and then or siply put the glue side to the top , and if that does not work you may need to get a polarizer film , tha now will able you to ajust it to your needs.
    Samtech
  2. ArcAiN6
    ArcAiN6 What's a Dremel?
    19 May 2005
    LCD wiring help
    ok, i found some LCD's on E-Bay for $2 USD, bought ten of them, just cause i'm bored :)
    Turns out the items weren't as listed though, they are " hamtronix HDM16216L-2-V3PT " that are backlit... the problem i'm having is i can't find any " howto's " on the internet for this model, but there is a wealth of information on thier website, but none of it makes sence to me because i don't know the first thing about electronic blueprints.. i was hoping someone could help me out by telling me what pin on a lpt cable goes to what hole on the board (there are 2 for power, and then 16 on the other end i'm assuming for data)
    the website address is http://hantronix.com
    Thanx in advance if someone can help me with this
  3. bluumax
    bluumax What's a Dremel?
    22 May 2005
    HDM16216L-2-v3pt
    Hi, I got some of the same LCD's. I found if you use a -5v reg on pin 3 they work fine. It's just a negative voltage contrast LCD. I got 10 too.
    PIN1, Gnd
    2, +5V
    3, -5V
    4 RS...etc. standard LCD pinout.
    Shawn.
  4. bluumax
    22 May 2005
    Graphic DG-12864-19
    Hi, Got a couple of those yesterday, the joys of working with a computer recycler, free parts & stuff. They came off Canon computers. Small towers.
    I couldn't find much else on the net though. Looks pretty standard for graphic LCD's though, I think.
    Shawn.
  5. Arioch_76
    Arioch_76 What's a Dremel?
    25 Dec 2005
    Hello All , Samtech can you upload the datasheet of the LCD DG-12864-19 Please because i can't find the datasheet !! and I want to connect this LCD on my computer
    Thanks a lot
    PS sorry for my poor english !!
    Have a nice day
  6. bixie_62
    bixie_62 Minimodder
    17 Jun 2004
    heya samtech
    any chance you could perhaps show how you achieved negative voltage?!
    i manageed to snag a 240x128 T6963C and a 4x20 both white on blue lcs for 60USD shipped!lol.
    but the graphic module requires negative voltage...how?!
    thanx
  7. Wolfe
    Wolfe What's a Dremel?
    7 Sep 2003
    Nope.
    You remove the film, rotate it 90 degrees, and replace it.
  8. I'm_Not_A_Monster
    I'm_Not_A_Monster Hey, eat this...
    22 Dec 2003
    damn, it's rectangular
  9. Ktulu
    Ktulu What's a Dremel?
    23 Feb 2006
    Hello guys,
    First, sorry for my bad english, but it's not my native language ;)
    I've removed the frame of my lcd (it's an 12864-19, same as the tutorial) for painting the frame. I don't want to invert the lcd screen ;)
    After mouting the protective frame again (I've tight the metal clips has they were originaly in the LCD), my lcd had strange reaction :
    There is some pixel line who are not actived and a "black fog" in the screen ... :(
    The cause of that is the removing of the frame...arggg
    How can I scan stop that ?
    THX very much for the help you can give me !
    Nico
  10. I'm_Not_A_Monster
    22 Dec 2003
    i dont think the X in the middle can be fixed, it looks like it was smashed w/ something, BUT I AM BY NO MEANS AN EXPERT!!! i just want to emphasize that. i could be wrong
  11. Big_Adam
    Big_Adam What's a Dremel?
    6 Jan 2004
    Ktulu, you have to cheack the film is on right and the correct way round i thin.
  12. keir
    keir S p i t F i r e
    5 Oct 2003
    I think thats the xBox logo?
  13. Big_Adam
    6 Jan 2004
    well......it is. thats why xbox is written benth the big X. i think he want to know how to fix the weird lines going across.
  14. I'm_Not_A_Monster
    22 Dec 2003
    yeah... i knew that... i was just um... testing you guys! yeah, testing
  15. H311R4153R
    H311R4153R What's a Dremel?
    28 Mar 2005
    Probably the frame isn't secured as tight to the LCD as it should be. Try and push it on further, but gently trying not to break the LCD.
  16. Skylined
    Skylined Minimodder
    3 May 2003
    Ktulu, take away the frame, move the LCD a lil bit to the right or left, grip the LCD from the borders where the golden contacts are, and check if it starts showing everything as normal.
    Once you got the LCD in the right position, put the frame back on, and make sure that the frame is pushing the LCD against the PCB.
    If you leave the LCD loose, some lines will be dimmer or won't show up at all.
