Development [TUTORIAL] Lens Effects for 3DStudio!!
Discussion in 'Software' started by Kevo, 15 Jul 2002.
  1. Kevo
    Kevo 426F6C6C6F636B7300
    9 Sep 2001
    Requested by Ubermich again :D
    Just a quick one...
    START
    [1] Open the max file you did in my last tutorial, you did save it right? ;)
    [2] Select your main Omni Light.
    [3] Scroll down the modifier and expand the Atmosheres & Effects tab then add Lens Effects.
    [4] Click on setup and then add the various effects here.
    [5] For best glow results try using the same colour as your light in the second radial colour (its the red one ;)) property.
    [6] Your done time to render!
    This is the kind of thing you can get...
    or
  2. Ubermich
    Ubermich He did it!
    21 Jun 2002
    w00t!!! I'm SO going to try this as soon as I'm done rendering! (appx 10 minutes :p )
    Edit: BTW, what did you use for the bottom one? Star? Grr, I add a few little things to an older scene and render times go up 500% :rolleyes: :p
  3. Ubermich
    Ubermich He did it!
    21 Jun 2002
    Ok, I WAS playing with this, but when trying to render what I decided was probably going to be the final... I crashed. When I tried again... I crashed. So I'm done with 3ds for the day, tomorrow (later this evening across the pond) I will split it up to render it in 1/4's :sigh:
  4. Kevo
    9 Sep 2001
  5. Ubermich
    Ubermich He did it!
    21 Jun 2002
    I stopped playing with that scene for the day and instead made this!
    I'm trying to figure out how to include/exclude objects from my lights now :(
