HTPC TV Capture Cards
Discussion in 'Hardware' started by okenobi, 22 Dec 2010.
  1. okenobi
    okenobi What's a Dremel?
    3 Nov 2009
    I want off air HD on my PC. I have access to a quad LNB and shotgun cable at present, but no active Sky subscription and I may well move to an aerial location in the near future.
    What are the best options? Can I get a card that will do Freeview AND Freesat?
  2. adam_bagpuss
    24 Apr 2009
    i believe you can
    didnt bit-tech or custom PC review a TV card that had both on although if i remeber it was 1 or the other not both at the same time so isnt really dual-tuner.
  3. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
  4. saspro
    saspro IT monkey
    23 Apr 2009
