Graphics TV card -Sound
Discussion in 'Hardware' started by Ryu_ookami, 7 Jan 2007.
  1. Ryu_ookami
    Ryu_ookami I write therefore I suffer.
    11 Mar 2004
    I have just installed a TV card that I have had floating about for a while its working perfectly picture its detected all he channels and even teletext but for some reason I have no sound I think its down to one of the settings but I am not sure
    the card is detected as a flyview video primo 30 so it is an old card but I would like to get it working correctly so does anyone have any ideas please.
  2. specofdust
    specofdust Banned
    26 Feb 2005
    you got the TV cards output going into the soundcards input?
  3. ComputerKing
    8 Sep 2006
    loll . you kidding me , I have this problem from ages . It was every thing perfect , One day no sound , So I tried allot of things , like change wire , sound card , nothing work , so I throw it into junk then get msi tv@master that I don't like the picture allot , then get my babe 1950xtx :D ,,
    I think that the chip burn or some thing on this life-view !!! its good normal TV tuner i can say , but what to do !!!
    good luck my brother , check the out put and in put like specofdust said and see your luck , I hope its good !! Also maybe the jack get damage quickly !! or so , But I hope it work with you , Not like mine , check the drivers too and software . bye , CK
  4. Ryu_ookami
    11 Mar 2004
    Um...no? I've got the tv antenna cable plugged directly into the antenna socket on the tv card. How would I go about linking it to the sound card? I thought the tv card would process the audio as well. I've never set a tv card up before so you'll have to bear with me if I ask some really stupid questions.
    EDIT: Fixed it. I checked it again and realised I'd plugged the speakers into the wrong place.
  5. ComputerKing
    8 Sep 2006
    try to do like this photo !! the red line the sound cable !!
    Good luck , Bye . CK
    lol edit : Im too Slow :duh: :duh: :duh: :duh: :duh: :wallbash: :wallbash:
