Graphics Tv-card?
Discussion in 'Hardware' started by Carbon, 3 Apr 2004.
  1. Carbon
    Carbon Banned
    8 Jan 2003
    Can anyone recommend a Tv card? i dont need a new graphics card, Mine i works well. But i'd like the tv card to have Radio function aswell and maybe (but not bothered) freeview connection.
    thx :D
  2. Lupine
    Lupine What's a Dremel?
    18 Dec 2003
    http://www.nebula-electronics.com/products/products.asp?class=digitv
    Is apparently a very good card. Has Freeview, and though it doesn't have specific FM input, you can get DAB channels on it.
    It does analogue capture too, although it's primarily a freeview tuner card, but from the reports I've read, it's capture is really rather good quality.
  3. herbs
    herbs Nobody but us chickens
    7 May 2001
    I have the Nebula and it definately the best freeview card around it has an 7 day electronic programme guide and many other bits but it's not cheap its £119 ish. I would get a cheap SAA 713x card such as videomate gold cards(http://www.tekheads.co.uk/s/category?category=19) these can be had for about £35 but this not freeview cards. I have an Tevion xpert 7134 (SAA 7134) but have issues with it so I can't recommend it but other people say its a good buy. None of the tv cards I know of can get DAB radio, you will have to buy a seperate card for that.
  4. Lupine
    18 Dec 2003
    I didn't mean that you could receive DAB broadcasts directly, but AFAIK, digital radio channels are broadcast on freeview (I have Sky, so I don't know from personal experience, but Sky has radio channels) and I think they're even broadcast at higher quality than over DAB transmission.
  5. herbs
    7 May 2001
    Yes you can get radio channels on DVB-T or freeview as its known here. They not excatly a wide range but you can get the bbc radio channels and kiss etc.
