Graphics Tv Out Problemes...should be simple please help a fellow nerd
Discussion in 'Hardware' started by fuzzygoblin, 8 Aug 2004.
  1. fuzzygoblin
    fuzzygoblin What's a Dremel?
    19 Oct 2003
    Hey guys and Gurls, Iv got a gefore 5200fx (dont laugh), and im trying to use the svideo out to a 34cm tv i have, but when i connect it all up...with the svideo to composite cable that came with the card and set it to extend my desktop to the 2nd monitor(tv) the tv just flickers...it works like if i click identify the screen number apears on the scren but flickes and scrolls (at the same time).
    Can any one please help? :)
  2. TMM
    TMM Modder
    12 Jan 2004
    have you got NTSC/PAL set to the right one for your tv?
  3. fuzzygoblin
    19 Oct 2003
    you cant change it...it uses video players and stuff from down here
  4. TMM
    TMM Modder
    12 Jan 2004
    i mean like, if your TV is NTSC, you set your card to output NTSC, instead of PAL.
  5. fuzzygoblin
    19 Oct 2003
    oh ok sorry, do you know were i change it?
  6. Guest-16
    Guest-16 Guest
    TV out settings in the display properties.
    Reduce the desktop size to 640x480/800x600. Make sure its interlaced (i) not progressive (p) output.
  7. MR BUNGLE
    MR BUNGLE Shoddymodder
    19 May 2003
    Yepp... Also check the refresh rate...
    Most TVs will not like anything other than 60hz...
    - Not sure how this works with Nvidea tvouts, but your primary monitor may need to be set to the same refresh rate
    (or that may just be for dodgy old ATI cards)
    Cheers, MrB
