TV Troubles
Discussion in 'Hardware' started by kirkham85, 11 Jun 2002.
  1. kirkham85
    kirkham85 What's a Dremel?
    13 Feb 2002
    Got a PCI TV CARD from Hauppauge but having a few small probs.
    1: Remote control Does not work.
    2: Can view tv in full screen but when there is movement in the picture it goes blurry, however when the picture is static its crystal clear.
    Running it with XP and have downloaded the latest drivers but no luck so far.
    Wondering if it could be my crap Riva TNT2 M64 Graphics Card?
    Any Ideas?
  2. NiHiLiST
    NiHiLiST New-born car whore
    18 Aug 2001
    I have the same problem with the screen. It keeps lines from the previous screen, and gradually updates them. It's really annoying. When I resize the window it is worse at larger sizes.
    The best way to cut this down the most is to get the latest version of the WDM drivers, and v3.39 of WinTV2000. Then go to the preferences menu, and go to the deinterlace tab.
    Set it to single field and check wide. It seems to improve my picture.
    Hope this helps, let me know if it does or not though bud.
