A/V Tv-Tuner card for gameing
Discussion in 'Hardware' started by DivineSin, 22 Mar 2005.
  1. DivineSin
    DivineSin What's a Dremel?
    23 Apr 2004
    I want to get a tv-tuner card for viewing games (ps2/gamecube/whatever i buy in the future) on my pc. I have a budget of around 200 dollars and i would like the card to have both composite/component in but only composite is really needed. So pretty much i'm looking for a tv-tuner that has the best videoquality (not too interested in the actual tv-tuner or the recording). Pretty much just want to play the games with it.
  2. star882
    star882 What's a Dremel?
    19 Mar 2003
    One thing TV cards with video capture aren't good for is gaming. The data buffering will add a lot of latency.
    Besides, you are aware that the PC is the ultimate gaming device, right? There is a reason why LAN parties almost always use PCs.
    However, if your gaming console has component output, a simple switchbox and some cables may be all you need if your monitor can take sync-on-green. Many good LCD monitors can also take composite and s-video input. A few even have a component input (note that VGA is also component, although it may not support sync-on-green) that natively supports sync-on-green, eliminating the switchbox.
    If you can't do it, I'm afraid that the answer is, "Just game on your PC."
  3. Guest-16
    Guest-16 Guest
    Try looking for a card with the ATI Rage Theatre 550 chip - dogs bollocks for video in/out apparently.
