HTPC TV tuner questions...
Discussion in 'Hardware' started by Superlunchbox, 17 Feb 2006.
  1. Superlunchbox
    Superlunchbox What's a Dremel?
    13 Jan 2004
    Hello all,
    I'm building a HTPC, and I'm curious which TV tuner is the best to buy. I'm looking for quality, and I'm not trying to spend over $200 to get it. I have a 50" Samsung DLP, so quality is important to me. I was looking at the Haupage selection, like the PVR 150, and 500. I've since learned it's better to get 2 150's than 1 500, because of interference issues. I'm thinking about getting the Diamond PVR550, because on Newegg it comes bundled with a Firefly remote.
    Questions, concerns, Comments Please. I don't want to buy this and it not do what I want, which is to record TV shows, and Play DVDs.
    System Specs:
    MSI 865PE Neo3-V MoBo
    MSI FX 5200 128MB DirectX 9.0 Compatible
    Intel Celeron-D 326
    No hard drive as of yet
    Tagan 480 Watt PSU
    Antec Overture II, or ThermalTake Tenor VB2000BNS
  2. herbs
    herbs Nobody but us chickens
    7 May 2001
    For quality picture on standard defination analogue signal the pro 550 will give you a better picture quality than the pvr 150 or pvr 500. But my view is that the pvr 150/500 has better support from 3rd party applications.
    I would swap the fx5200 for a 6200 or 7300 and tha targan for a seasonic psu if you haven't aready purchased them yet. On the hard drive front look at seagate or samsung for low noise.
    Finally a 50" tv will show all the faults of standard tv resolution so be warned.
  3. Superlunchbox
    13 Jan 2004
    I understand about the TV. Just trying to capture at a good quality for when I watch it later. I don't want the picture to be worse than it is now. As far as the graphics card goes, too late. I got a good deal on it. Also, already had the PSU laying around. I can upgrade that later. How much of a difference is there between the haupage cards and the 550?
  4. herbs
    7 May 2001
    There is a difference but not a massive difference, the hauppauge cards are 10bit whilst the ATi is 12bits and has more filters to improve picture quality. I would stick with the hauppauge due to having better support and more driver releases even beta drivers at www.shspvr.com
