News TVersity to receive major facelift
Discussion in 'Article Discussion' started by CardJoe, 16 Jan 2008.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    i use this for my PS3 as well very usefull, i have only been able to stream unconverted Xvid files tho cant get the transcoder to work on older Xvid files that will not work on the PS3
  3. cjoyce1980
    cjoyce1980 What's a Dremel?
    17 Jul 2007
    xbox 360 and ps3 now support mp4 playback (that includes divx, xvid, apples mp4 format, etc....) so you only really need this if you want to stream content to your wii
  4. Darkedge
    Darkedge Minimodder
    26 Nov 2004
    cjoyce1980 the 360 supports full divx playback including mp4, the PS3 will only do the mp4 part of that spec.. there is also alot of other codecs/codec profiles and file extensions that the 360 and PS3 do not support.
    TVersity is great for all of those :)
  5. salesman
    salesman Minimodder
    29 Apr 2007
    yea its not just transcoding, but also steaming it and the level of control it gives, which is extremely nice if you have and old PC like mine. My only complaint with it is that it is in beta therefore it doesn't have an ease of use but neither does my 360
  6. devdevil85
    devdevil85 What's a Dremel?
    29 Nov 2006
    I was having a lot of issues w/ TVersity and the PS3, but for some reason after uninstalling everything (codecs mainly) and reinstalling everything TVersity (from what I have seen at my friend's house thus far) is working. When I was having problems, TVersity kept giving this MediaServer.exe error upstairs on the computer and then on the PS3 it would give this error code. Luckily it's not "timing out" or giving any errors (knock on wood) and I love the ability to transcode when necessary because streaming DivX video is so much faster now that it doesn't need to compress/transcode anything.......
Tags: Add Tags
