Case Mod - Complete Tweaked Torrent
Discussion in 'Project Logs' started by TerHorstCustoms, 3 Jan 2022.
  1. TerHorstCustoms
    TerHorstCustoms Minimodder
    29 Jan 2020
    Happy 2022! Time to kick off the year with a new project :clap: Let me introduce the 2022 follow up of the Tweaked Meshify S2 build that I build back in 2020.
    The goals of this build is to integrate the unique layout of the Tweaked Meshify S2 in to the Torrent case with bigger radiators while also applying improvements to overal general design based on experience from the previous build.
    A big thank you goes out to Fractal Design for there continuous support on projects like these!
    The parcel from Fractal had a few supprises inside of it next to the two light gray Torrent cases and the Ion+ 2 860w PSU. Some Swedisch candy :grin:
    Time to start stripping down the first case
    After drilling out all the rivets it was time to start drawing the orignal frame parts in CAD. These will from the base to work from to integrate the Tweaked Meshify S2 layout. Because of this it was important to draw all small details as well since those could give headaches later on if they are missing.
    Bottom
    Front left
    Front right
    Top panel
    While trying out some component layouts in a 2D drawing I quickly found out that the orginal Torrent frame wouldn't have enough room to fit two 420mm radiators on a angle while also fitting a normal ATX board. Because of this I started looking for different possible solutions like making the case bigger.
    After doing some measurements on plastic toppanel I found out that it will be possible to extend the case by 50mm in total. This should give just enough room to fit the 420mm radiators with a normal ATX size motherboard :clap: A quick mock up the extra room with a mirrored front frame.
    This floating frame will be base on which I'm gonna continue working on and fit all the hardware inside :dremel:
  2. The_Crapman
    5 Dec 2011
  3. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    Torrent front panel is gorgeous :jawdrop:
    Are you sure you need both cases ? :grin:
    TerHorstCustoms likes this.
  4. TerHorstCustoms
    29 Jan 2020
    Yes the front is epic! :jawdrop:
    I will need 8 parts from the second case :cooldude:
  5. TerHorstCustoms
    29 Jan 2020
    Update time, after the orignal frame parts its was time to design custom parts :clap:
    After finishing the frame extensions to make the frame one part again it was time to testfit 3D parts to see if it still all could work.
    Its a really tight fit :eeek: but the rads just clear the orginal top panel :happy:
    Time for internal framework :hehe:
    Made a 3D model of the GPU with waterblock to design a mounting system.
    It will not be using the PCIE bracket and hide the PSU vent cutouts that will be used to get some airflow past the motherboard.
    The sheetmetal design is done for roughly 90% now, small details need to be added one some places but all the big work is done now. After the sheetmetal is done it gonna be time for the distro plate in the back + cable managment planning.
    Cheapskate likes this.
  6. TerHorstCustoms
    29 Jan 2020
    Small update :)
    After tyring a few configurations I founds something that will work for the GPU, its a tight squeeze but will fit :hehe:
    First setup for the cable channels for some clean cable management.
    With panel combs
    Pump integration, going for pump mounted to the reservoir/ cable plate to make installation easier.
    That is it for now again, still more to do but the details always take a lot of time :lol:
    No X, kim and Cheapskate like this.
  7. TerHorstCustoms
    29 Jan 2020
    New update time :clap:
    Finishing the sheetmetal and plexi res / cable managment plate went a lot quicker then I thought :hehe:
    Added front side cover strip for the new plastic parts to go on to, this will be done to make the case look as stock as possible :)
    Side reservoir build into the cable management plate, its a snug fit with pump but works
    Cable management
    IO area
    Final step before making the parts is double check the mounting holes of the orignal plasic parts. More soon:clap:
  8. TerHorstCustoms
    29 Jan 2020
    Life has been busy with graduation internship but now is all over and that means vacation :clap:
    Yesterday afternoon a local sheetmetal company dropped of all the newly designed sheet metal parts for the build. This means more progress updates later this month :grin:
  9. TerHorstCustoms
    29 Jan 2020
    Update time; Turning second case it to more bits
    Cutting it up
    Prepping case and new parts for paint
    Painting done :)
  10. TerHorstCustoms
    29 Jan 2020
    Vacation = update time :clap:
    Paint prep for distro and radiators
    Assembly time, first up motherboard standoffs
    On to the frame
    Some small tweaks needed on the TG panels
    Next up the orignal plastic parts
    Using some vhb tape to mount black strips that will from the base for the case grey matched strip.
    Internal covers line up great :)
    Final bit for today, the underside plastics and dustfilters
    Mounting the dustfilter rails with magnets
    Both sides done
    That is it for now, more soon :grin:
    Cheapskate and kim like this.
  11. TerHorstCustoms
    29 Jan 2020
    Update, case finished :clap:
    First up, mirrored top panel by making a template
    Transfer
    5mm spare :grin:
    After trimming, not perfect but will do :)
    Next covering the frame extionions, made the out of the second top panel.
    [​IMG] \
    Cleaning up the back side
    Final tweaks with the file
    All done and ready to fit with double sided tape
    All fit and finished :grin:
    Next up finally system assembly time, final parts for that should arrive tomorrow :)
    kim and Arboreal like this.
  12. Cheapskate
    13 May 2007
    :thumb: It looks 'stock'. Seamless mod, once again.
  13. TerHorstCustoms
    29 Jan 2020
    Thanks :) Many CAD hours paying off :grin:
    Arboreal likes this.
  14. TerHorstCustoms
    29 Jan 2020
    Final update time :grin:
    Final hardware test before installation of block and case.
    Block time for FE goodness :)
    Assembly time, but first time for shot internal AC power cable
    Front IO cable management behind the motherboard
    Board and first rad in
    Its a snug fit
    Cables around the PSU area
    Sug riser fit with the gpu
    ZTM prep for the top and hardline time in the front.
    Leaktest on 0.3bar, all good
    Leaktest on 0.5bar, one fitting needed half a turn extra
    Small tweaks to the memory
    All filled up with clear liquid and time for some eye candy :clap:
    Dergan, No X, 4LIEN and 1 other person like this.
  15. Cheapskate
    13 May 2007
    Thoroughly STUFFED in that case. :lol:
  16. kim
    kim hardware addict
    10 Jan 2016
    Very impressive modding session on this case :jawdrop:
    Tweaked mechify was such an original design but I find this version absolutely flawless :rock:
  17. TerHorstCustoms
    29 Jan 2020
    Exactly :)
    Thank you! Meshify was a great first try at this new layout but as always there is room for improvment. This has some improvements but there is still room for more, I guess in followup on this :lol:
  18. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Very good build! I suggest a protection grill on the rear fan, otherwise you risk your fingers! :grin:
  19. TerHorstCustoms
    29 Jan 2020
    Yea that might be smart thing to do :naughty:
