Modding U.V. paint
Discussion in 'Modding' started by Gascan1888, 10 Jan 2005.
  1. Gascan1888
    Gascan1888 New Member
    15 Dec 2004
  2. kobaj
    kobaj Banned
    4 Jul 2004
    Did you read the features of the sleeving. :D
  3. Stormtrooper
    Stormtrooper Shh...
    26 Mar 2004
    UV resistant just means that it will not degrade under exposure. If you read the first link, it says that the spray stuff can be made permanent by using a clear coat... Pretty easy.
  4. Gascan1888
    15 Dec 2004
    but how well will that work on flexible sleeving is more my question i guess
  5. Stormtrooper
    Stormtrooper Shh...
    26 Mar 2004
    It wont cover 100% but it should keep the uv paint from wiping off. Since the sleeving isnt made of fabric from what I can tell, there shouldn't be a problem.
  6. Zephyr
    Zephyr Go V-Boy, Go!
    1 Oct 2004
    OT, but kobaj, why did you change your user name from jtggg?
  7. mime genocide
    mime genocide New Member
    2 Sep 2004
    it works good on metal but your going to use 4-5 light coats to get good results.
  8. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    Spray on UV dyes won't stick to PVC sleaving
