uATX with PCI-X?
Discussion in 'Hardware' started by Moriquendi, 20 Aug 2008.
  1. Moriquendi
    Moriquendi Bit Tech Biker
    3 Nov 2005
    Has anyone ever seen a micro ATX board with a PCI-X slot? Im looking at building a NAS-on-steroids but but it seems that the board I planned on using has 64bit pci slots rather than PCI-X and my SATA card only works with PCI-X.
    Any help much appreciated.
    Moriquendi
  2. jbloggs
    jbloggs What's a Dremel?
    12 Sep 2007
    A PCI-X SATA card will (usually) work in a PCI slot but at reduced speeds....
    ________
    LIVE SEX
  3. Moriquendi
    3 Nov 2005
    This one doesn't seem to want to, besides which its a 16 port card and would be SERIOUSLY bottlenecked by the 133MB limit of 32bit PCI slot.
    Moriquendi
  4. Icy EyeG
    Icy EyeG Controlled by Eyebrow Powers™
    23 Jul 2007
    As you can see I have a similar doubt... And found part of the solution.... Now to find a place selling the riser card has proven more difficult than ever... :rolleyes:
  5. Moriquendi
    3 Nov 2005
    You mean like this?:D
    Great find, I wonder how transparent it is to the OS though.
    Moriquendi
  6. Icy EyeG
    23 Jul 2007
    THANKS! :jawdrop:
    :D
    Now to find an European store :p (my quote above was from the Scan forums, but so far no answer)
    My thoughts exactly. However, since the Asus WS motherboards use PCIe-PCI-X bridges without any problems, it should work fine (unless ASUS uses BIOS tweaks to make the bridge invisible to the OS... I don't know... :rolleyes:)
  7. Moriquendi
    3 Nov 2005
    I don't know whether you'll find a european shop though you could email that place and see if they'll export it.
    The tyan site suggests that its only compatible with one of their mobos which doesn't look good for general compatibility.
    Moriquendi
